October 13, 2026, 08:59:18 am
| | |-+  Number Plate With T Bars
Author Topic: Number Plate With T Bars  (Read 13064 times)
RIP356
« on: August 19, 2013, 22:25:57 pm »
Just wondering how you run a front number plate with T bars?
Down here its illegal not to have a front plate so any ideas or pictures would be appreciated.
Flow
« Reply #1 on: August 19, 2013, 23:19:12 pm »
Two collars setted on the plate and slipped on each t-bars, really simple  Wink
« Reply #2 on: August 19, 2013, 23:43:46 pm »
I use P-clips on the top corners, easy for it to "just fall off officer"...
2manytoys
« Reply #3 on: August 20, 2013, 05:27:19 am »
The rear can attach the same as the front. Bracket on the T bar to hold the frame....works good in the burnout box...
tee bars are great.
« Last Edit: August 20, 2013, 05:29:13 am by 2manytoys » Logged
« Reply #4 on: August 20, 2013, 05:36:58 am »
   HAHA, NICE!
Ted
« Last Edit: August 20, 2013, 05:39:49 am by DKK Ted » Logged
streetvw
« Reply #5 on: August 20, 2013, 09:27:36 am »
I made a bracket that out of 20mm electrical conduit with 2 25mm pieces of conduit welded on to the ends of it that slip over the top of the bars cheap and simple Wink worked so well my brother nicked it for his 67
« Reply #6 on: August 20, 2013, 14:24:41 pm »
simple i don't use front plate  Grin Grin Grin
RIP356
« Reply #7 on: August 20, 2013, 14:35:38 pm »
Now that looks cool, funny but I have just brought an old post up regarding buggy bars.
Where did you get yours from, I could mount my plate to that!
christophe
« Reply #8 on: August 20, 2013, 23:40:22 pm »
I took a pics of this nice setup on a danish callooker at SCC few years ago.
banditina
« Reply #9 on: August 21, 2013, 09:32:10 am »
Deanodynosaurs
« Reply #10 on: August 21, 2013, 11:56:15 am »
I did mine by making a bracket up that bolt underneath the floor of the wheel well. It can be easily removed when i dont want it there, and fitted for road use. Smiley
Not the best pictures of the bracket, but they give you the idea. If your intrested i can put some pictures of the bracket up later. Smiley
Dude  Cool
RIP356
« Reply #11 on: August 21, 2013, 12:13:47 pm »
Dude  Cool
I would appreciate that thanks
Deanodynosaurs
« Reply #12 on: August 21, 2013, 12:17:09 pm »
Okay, pics are on my home computer, so i'll do it tonight. Smiley
Dude  Cool
« Reply #13 on: August 21, 2013, 15:24:27 pm »
i've got my buggy bar from the shop where i go to take parts , they're the one you can find in every vw shop  Wink
and yes you can put a plate on  Wink
Ovalboy
« Reply #14 on: August 22, 2013, 19:10:09 pm »
Wow what a beautiful car
Deanodynosaurs
« Reply #15 on: August 22, 2013, 22:11:31 pm »
RIP356,
I did have better photos than this, but my laptop died a few months back and I forgot I'd lost them. Sad
Anyway I'm sure you'll get the idea. Basically there's 4 holes in the spare wheel well, and this frame (see below) bolts underneath using some finishing washers and bolts, (so it doesn't snag the spare wheel, and to finish it nice).
Hope this helps.
Dude  Cool
RIP356
« Reply #16 on: August 22, 2013, 22:34:13 pm »
Thanks for that
RFbuilt
« Reply #17 on: September 19, 2013, 06:44:35 am »
i know its late to the party LOL   Cheesy
here's what i did to my daily driver , a 1972 late model "economy" beetle
kinda hard to see but,  what i did was get some form of steel flat thats about 4-5mm thick and half an inch wide
drilled holes for the platenumber ,  and have it long enough that you can bend an L type of tab on the end  (drill the Tbar's side)
fasten with a nut and bolt (allen head)  and you have yourself a plate holder you can angle how you want , sloped down or sloped up,
me i fastend it to angle close to the same as the Tbar itself
another shot
Balocco
« Reply #18 on: September 26, 2013, 22:02:06 pm »
Is it your car? Happened to walk by it Friday evening two weeks ago.
Really nice! Nice work with the plate holder as well.
Type 1 59 fake split project, Type 1 "US 67", Type 2 61 11W sunroof, Type 2 1961 15W
Ron Greiner
DKP II
« Reply #19 on: September 28, 2013, 23:50:38 pm »
on my 68 club car I never ran a front plate till I started getting fix it tickets, so I took two early bug bumper overiders support tubes and bolted them to the bottom of the spare tire well,  leaving the 90 degree angled end sticking forward, then I bolted the bottom two holes of the license plate to them.  there were already two drainage holes in the bottom of the spare tire well already there, so it was bolt on
« Reply #20 on: September 30, 2013, 04:33:14 am »
I was surprised that no one had mentioned this.
I used this method on my '67. Some small differences though. I used some large fender washers on both top and bottom of the spare tire well to help distribute the weight. I also bent the ends that the plate bolted to so the plate would lean back some instead of being straight up and down.
Rick
