September 21, 2026, 10:55:14 am
Latest Member: Bad Habit
| | |-+  Removing materiel from the face of the case instead of the end of the barrel.
Author Topic: Removing materiel from the face of the case instead of the end of the barrel.  (Read 4187 times)
Martin Greaves
10.88@128.58
« on: August 27, 2013, 19:16:46 pm »
Can a safe amount of materiel be removed from the face of the case where the barrels would sit, instead of making the barrels shorter.
If so how much would that amount be.
Thanks Martin
cameron shorey
« Reply #1 on: August 27, 2013, 20:26:52 pm »
Thanks Martin
Yes, you can deck/face the case. The depth of cut depends on how deep the imperfections are, and how much deck height you want  (Piston top to top of cylinder).
Horsepower, reliability, cheap... pick two.
Martin Greaves
10.88@128.58
« Reply #2 on: August 27, 2013, 22:38:44 pm »
Thanks I already understand all of that.
I have just picked up a NOS AS21 case but someone had accidental machined it wrong when cutting it for 94mm pistons.
So what I'm after is the safe amount that can be removed from the face of the case without making that area of the case to weak.
Martin
