October 13, 2026, 10:39:43 am
CR (Check my math)
Topic: CR (Check my math) (Read 9024 times)
CR (Check my math)
July 25, 2007, 17:09:29 pm »
Someone check my math please and let me know if I am doing this right.
Bore - 94
Stroke - 82
# Cyl - 4
Deck Height - .06 (copper gasket)
Head Volume - 51cc (What is the volume on a stock VW head?)
Compression ratio - 12.07:1 (And yes I know that is high)
Re: CR (Check my math)
July 25, 2007, 17:19:53 pm »
thats what i make it.
use attached file to see, rename from txt to xls, as it is actually a MS Excel file
July 25, 2007, 17:24:53 pm »
I use a calculator on the net. Check
flat4ever.com
With your indication and translating the .06 (I suppose Pounds) in millimeter = 1.62mm the result is 10.14 cr.
July 25, 2007, 17:35:58 pm »
Quote from: lids_2001 on July 25, 2007, 17:19:53 pm
Okay thanks for the work sheet.
Quote from: j-f on July 25, 2007, 17:24:53 pm
flat4ever.com
The copper gasket is .06mm. Sorry i should have been more specific.
July 25, 2007, 17:57:36 pm »
I find 12.07 cr also with this calculator.
I don't know very much in mechanics,but 0.06 for the deck height is not a too small ?
The Ideaman
July 25, 2007, 18:01:01 pm »
Aren't the copper gaskets .060 inch? If so, then the compression ratio is 10.2 to 1.
http://www.cbperformance.com/enginecalc.html
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
July 25, 2007, 19:38:30 pm »
Humm, maybe it is inches. That would make more sense. I was surprised to get such a high ratio with that large of a head volume and a .06 deck. so to get close to 12:1 I would need something like a .04 deck and a 45cc head. Sounds pretty tight.
Last Edit: July 25, 2007, 19:40:56 pm by louisb
alex d
July 26, 2007, 10:38:15 am »
check the shim thickness with a micrometer, you never know
The Ideaman
July 27, 2007, 01:30:08 am »
41cc's with .060 inch deck gets you 12 to 1.
It is the soldier,
July 27, 2007, 01:46:00 am »
Wonder if you can get a VW casting down that much.
edit: actually with a 5 cc dome that puts me a 46cc which isn't too bad.
Last Edit: July 27, 2007, 01:47:47 am by louisb
The Ideaman
July 27, 2007, 03:32:35 am »
I had a set of VW castings with 28cc's in 'em. Made for a 13 to 1 1776.
It is the soldier,
