October 14, 2026, 05:32:51 am
| |-+  For sale!
| | |-+  2276 Turbo motor, Slicks, pro drag box, ercos...
Author Topic: 2276 Turbo motor, Slicks, pro drag box, ercos...  (Read 9724 times)
Stefan Rossi
« on: September 02, 2013, 20:05:06 pm »
Hello, I have just brought a yank and have no need for two race cars so therefore I am selling all the go-faster goodies off of my beetle.
First up is 2276 turbo motor
Motor was built buy me at Aircooled Engineering and has since only covered 600 miles since being built to turbo spec. (carried out approx 5000 miles previously as an IDA motor)
Spec:
2276cc with 7.8:1 comp ratio
Rotation assembly balanced
New Silverline bearings throughout
CB 82mm forged & nitrated crank
CB H beam rods with 3/8 ARP bolts
Mag case clearanced and full flowed ect (5600 miles old)
Gene Berg equalizer pulley
Kennedy Stage 1 clutch and daiken friction plate
Engle FK8 cam (600 miles old)
CB Straight cut gears
Scat lifters (600 miles old)
Scat 190,000 psi head studs
Mahle barrles and pistons, pistons have 7cc dishes
Total seal Gapless piston rings (600 miles old)
Deep sump
30mm oil pump
Berg releif pump cover
CB Round port heads with CB vw650 springs (600 miles old)
Originally Marty Staggs turbo set up modified by myself
Holley 850 cfm carb.
T peice with modified stock vw end castings (by daz chandler)
Spa Turbo T3/T4 turbo ceramic coated
Braided lines and AN fittings
Turbosmart 38mm waste gate with spare springs
Ceramic coated turbo header
MSD dizzy locked out at 24 degrees
Have ran this motor only 3 times down the track best time with only 7psi of boost and missing third gear was 13.1 @ 107mph. Motor has potentials for 10's with higher boost and more track time!
Sold as seen, as this is more or less a race motor that can be driven on the street I will not be giving a guarantee with it so to speak. If the new owner wishes to run 27psi of boost with it and starts breaking stuff that is not my problem. Obviously whoever buys this should know their stuff anyway Smiley
Motor runs very nice on the street and is a blast to drive. can be cruised around like a stocker and then all hell unleashed when you press the go pedal harder.
£5500 ono for all of the above
Rancho Pro Drag Plus Swing axle gearbox
This was a special order from Rancho with all the best parts and mods they sort for a T1 style box;
Gusseted case,
Cromo Mainshaft,
3.78, 2.26,1.56,1.12 ratios,
3.88 R&P,
Welded 3rd & 4th gear syncros,
Timken bearing conversion,
Cromo bearing retainers
Billet spool,
dual billet side plates,
loads of other small mods
I have 3 runs and 600 miles of road use on this box since i brought it
£1800
SAW race axles. Swing short axle New used for 600 miles but axles are from 2002 (stronger)
Used for 600 miles and 3 runs up the strip, pic was taken when they were new. I can take a recent pic tomorrow when I'm at work if needed.
SOLD
Berg mid mount powder coated silver SOLD
Used Rhino mounts and heavy duty cradle powder coated silver also SOLD
Street weight Erco wheels 2x 5 3/4 wide 5 rears one has a crack and has been welded. Holds air and balances up fine. £350 ono
Used but plenty of 'tread left' Pheonix 6 inch slicks SOLD
BAD series wide 5 rear disc brake kit for short axle car
Used for approx 5600 miles. shot blasted hubs with powdercoated gloss black centres.
sorry only pic i have until tomorrow
Discs kit & handbrake cables £500
My number is 07521510015. Would rather talk about the parts over the phone or via text than PM's. All parts located 2 miles from Birmingham city centre England.
Thanks for looking
Stef
« Last Edit: September 29, 2013, 19:22:33 pm by Stefan Rossi » Logged
Aircooled Engineering. Birmingham, England
www.ace-vw.com
Check us out on FB, www.facebook.com/aircooledengineering
www.dtavw.com
'67 vert
'67 Chevelle PT106mm turbo
'66 Lincoln
Stefan Rossi
« Reply #1 on: September 05, 2013, 21:48:48 pm »
Bump
Will consider deals for all parts
Need them all gone
Stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #2 on: September 05, 2013, 22:13:15 pm »
Slicks
gearbox mounts
2 porsche ercos
All SOLD, thanks
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #3 on: September 05, 2013, 22:24:52 pm »
some better pics
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #4 on: September 08, 2013, 13:57:58 pm »
Everything needs to go!
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #5 on: September 10, 2013, 20:45:33 pm »
Turbo kit and 2276 motor available separately Smiley
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #6 on: September 14, 2013, 13:03:24 pm »
considering all offers!
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #7 on: September 17, 2013, 01:37:56 am »
ttt
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #8 on: September 23, 2013, 20:01:56 pm »
Hello Smiley
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #9 on: September 29, 2013, 19:18:34 pm »
Axles and mid mount sold
Motor,  turbo kit, gearbox, rear disc kit and heads left. All OFFERS considered
will split turbo kit from motor
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Stefan Rossi
« Reply #10 on: September 29, 2013, 19:23:10 pm »
Some prices updated and still have 2 ercos for sale
Stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
