October 13, 2026, 15:27:01 pm
| | |-+  oilheater for sump
Author Topic: oilheater for sump  (Read 9357 times)
bang
« on: September 14, 2013, 10:17:25 am »
hey. i am building a autocraft turbo engine and want to run on methanol. want a oil header in my sump. what size should i use and what in the ideal pre heat temp??
have you guys seen where i can buy one. and are they 12 volt or 230volt??
« Reply #1 on: September 14, 2013, 10:33:03 am »
http://www.jegs.com/i/JEGS+Performance+Products/555/23675/10002/-1
Something like this, and I boil the oil to remove the methanol from it, takes an hour or so to get it real clean, then turn it off about 20mins before the 1st pass of the day, the only pain is they are 110volt so I carry a convertor from 240v-110v.
You can also get an aftermarket VW sump heater that goes on the outside and attaches to the sump plate, as sold in cold countries, not tried one for boiling oil yet though
bang
« Reply #2 on: September 14, 2013, 11:10:06 am »
okay thanks.
think i want 2 then and mound tem in serie so 220v should be okay.
« Reply #3 on: September 14, 2013, 11:47:39 am »
We have LOADS here in norway.... A place called "Hotshop" has a load of NoS/original heaters  Smiley
MeXX
« Reply #4 on: September 15, 2013, 19:19:35 pm »
Hi
My mill is also on meth  Grin
The first season I was running without heater. Every cold start I had allot of Methanol in the oil resulting in terrible wear.
Now I'm running a 1000W 230V heater.
I'm heating the oil (8 Liter) up to 100°C  which takes depending to ambient temperature from 25 to 60 min.
When the engine fires up the oil heats the parts quickly and is dropping about 20-25°C.
MeXX
« Last Edit: September 15, 2013, 19:37:05 pm by MeXX » Logged
Drag or Die
bang
« Reply #5 on: September 15, 2013, 19:58:18 pm »
mexx where did you get your heater?
MeXX
« Reply #6 on: September 15, 2013, 21:08:17 pm »
Hi
It's a replacement part for a household dish washer. Roll Eyes Roll Eyes
MeXX
Drag or Die
Andy Sykes
« Reply #7 on: September 15, 2013, 21:10:03 pm »
I've made my own from glow plugs worked very well on 12v
MeXX
« Reply #8 on: September 16, 2013, 14:12:55 pm »
Dear Andy
How much power does it have? Huh
Because mine has 1000W which is really not to much that would be over 80 amps @ 12V ?
MeXX
Drag or Die
« Reply #9 on: September 16, 2013, 14:19:06 pm »
Any pictures Mexx? I thought a dish washer heater was basically a long cable and way to big to fit in sump.
Thanks!
-BB-
MeXX
« Reply #10 on: September 16, 2013, 14:36:17 pm »
-BB-
Dear Kalle
The long cable is basically for connecting the dish washer to the power supply. Grin Grin
MeXX
Drag or Die
JS
« Reply #11 on: September 16, 2013, 14:39:10 pm »
-BB-
Dear Kalle
MeXX
 Cheesy Cheesy Cheesy
Signature.
« Reply #12 on: September 16, 2013, 14:49:29 pm »
-BB-
Dear Kalle
MeXX
Dam!! Now you tell.. I tried my best to fit that dam thing inside my sump but gave up after a while and ended up using a 300W Defa one instead. Works excellent since I`m never in a rush.
Andy Sykes
« Reply #13 on: September 16, 2013, 15:18:55 pm »
Dear Andy
MeXX
Hi Mexx
an extract from my build thread  below
i did a bit of testing on the heater pockets to see if the heat was less concentrated at the tip and seams to work ok took about 30 mins to warm 1L of oil to 90 deg C
thought i would weld in the heater pockets and give it a try
20amps needed for all 4 plugs
and in one hour we have just over 90 Deg C and 50 Deg C in the oil feed line
so looks like that works Smiley
cheers andy
