September 22, 2026, 09:51:44 am
| |-+  For sale!
| | |-+  Fiberglass 68- front fenders, Lasercut parts of the shelve, Brake parts etc.
Author Topic: Fiberglass 68- front fenders, Lasercut parts of the shelve, Brake parts etc.  (Read 3843 times)
-Alex-
« on: September 18, 2013, 21:26:03 pm »
I have some stuff to sale, feel free to ask by private message or email: alexstorskrubb@jippii.fi
Dont ask on this topic, because i dont watch it every day.   If the price is too high, you can give me a nice offer  Grin
Lasercut parts available right away:
-2 x 12-1 134x6mm Trigger wheel with sensorbracket for honeywell 1gt101dc sensor
-2 x VW sign 210x4mm -  21€ each or 35€ both
-2 x VW sign 68x4mm -  12€ each or 20€ both
-1 x transaxle midmount kit with flange and two bended ears - 40€
-1 x 200mm flywheel puller with M16 nut at center - 35€
Porsche PCD hats for wilwood rotors
-Two for front which have 12x7" pcd for 1/4 UNF bolts.  10.9 bolts come with these.
-Two for rear which have 8x7,62" pcd for 5/16 UNF bolts.  10.9 bolts come with these.
Made from 6082-T6 aluminum and anodized to black.
There is a lot of rotors available for these rotors:
http://www.wilwood.com/Rotors/RotorList1.aspx
70€ each or offer
Kerscher fiberglass front fenders for beetle 68-, 3cm inner widened, NEW.
Made in Germany, all holes drilled, steel headlight bucker, best QUALITY ever!
At the picture is outer widened.
New at kerscher 399€
275€ or best offer
Boxster brake caliper adapters from Kerscher 4-piston Porsche brake kit.
http://www.kerscher-tuning.de/kaefer/index.php?gruppe1=Bremsanlagen&gruppe2=Bremsanlagen+VA
Fits with 300-320x20-24mm rotors.  Originally used with 278x20mm rotor at the kit and also brake caliper M10 holes at spindle were moved inwards 22mm by Kerschers installation manual.
60e
Aluminum t IDF/DRLA velocity stacks
4 x stacks, with up to 46mm carbs.
30e
« Last Edit: September 24, 2013, 08:39:31 am by -Alex- » Logged
-Alex-
« Reply #1 on: September 24, 2013, 08:39:41 am »
up
-Alex-
« Reply #2 on: October 01, 2013, 08:52:27 am »
up
