July 22, 2026, 08:10:09 am
Lotus67
Squirrel Fans
Topic: Squirrel Fans (Read 14721 times)
Martin Greaves
10.88@128.58
Squirrel Fans
July 26, 2007, 23:29:44 pm »
Hi guys where the best place to buy Squirrel Fans or is there a easy way of making some. As i have not really look at any close up before.
Re: Squirrel Fans
July 26, 2007, 23:59:32 pm »
There are two ways to do them you can cut them and the Dual port head tin up and weld or rivet the fans to the Tin or you can mount them inside the car on the firewall adding a 2 inch neck and welding a plate across the head tin with a 2 inch neck then use duct hose to go from the firewall to the head tin I ran Fans on my street car I installed two collars on the back of the fan shroud with the fans mounted inside on the firewall with a short hose going from the fan to the back of the housing that way you can race with the belt off and use the fans, only one draw back with this set up you have to cap the fans off inside the car when your not using them otherwise you lose some of the cooling from your stock fan shroud it is easy to cap them off I made two 4 inch Round Metal plate's with velcro just stick them on when there not in use..
71CALRIPPER
Re: Squirrel Fans
July 27, 2007, 10:44:29 am »
got any pics and specs of the fans you used, very interesting subject
Re: Squirrel Fans
July 28, 2007, 02:04:26 am »
Quote from: 54caldub on July 27, 2007, 10:44:29 am
here you go! If your in Calif Graingers sell's them for $52.25 each.
DC Blower, Air Flow @ 0.000 Inch Static Pressure 176 CFM, Speed 1875 , Voltage Rating 12 VDC, Current Rating 5.10 Amps, Wheel Diameter 5 1/4 Inches, Wheel Width 2 1/2 Inches, Inlet Diameter 4 1/2 Inches, Air Flow @ 0.100 Inch Static Pressure 170 CFM Grainger Item # 2C646
Price (ea.) $52.25
Brand DAYTON
Mfr. Model # 2C646
Ship Qty. 1
Sell Qty. (Will-Call) 1
Ship Weight (lbs.) 4.15
Usually Ships** Today
Catalog Page No. 3052
If you were using them with a fan shroud with them mounted on the inside firewall you need to use the covers I talked about above so the air from the fan shrould dose not blow in when the fan are not being used..
Last Edit: July 28, 2007, 05:09:57 am by Shubee2 (DSK)
Martin Greaves
10.88@128.58
Re: Squirrel Fans
July 28, 2007, 10:59:17 am »
Thanks Shubee just been onto Grainger web site need to get some for a winter project. Well i might as well start now as we have not had summer yet it just keeps raining.
Last Edit: July 28, 2007, 11:50:56 am by gold65turbo
Re: Squirrel Fans
July 28, 2007, 13:27:03 pm »
Quote from: gold65turbo on July 28, 2007, 10:59:17 am
LOL Sounds like you Live In Texas? Since I moved here from Calif it has Rained about three times a week and Snowed five times? and everyone Told me Its HOT in Texas LOL I wish The SUN Would Stay Out LOL I built a Big Air Conditioned Shop to Build my Cars in And I Think I am going to Need the Heater Instead..
Hope the INFO. helped Thanks Shubee
Russell
Re: Squirrel Fans
July 31, 2007, 00:27:48 am »
Shit... I thouught you were talking about the Red and Grey ones Martin !
Best Regards
Russell
Joe_G
Re: Squirrel Fans
July 31, 2007, 08:40:24 am »
The ones that came with The Sting were Dayton fans. You can still get them from
http://www.electricmotorwarehouse.com/dayton_blower.htm
but I got some new ones from Mr Taylor that were surplus (note to self - must give Martin the money for them!!
Re: Squirrel Fans
July 31, 2007, 13:21:48 pm »
Quote from: Shubee2 (DSK) on July 28, 2007, 02:04:26 am
Price (ea.) $52.25
Brand DAYTON
Mfr. Model # 2C646
Ship Qty. 1
There still Cheaper from Graingers Joe
Re: Squirrel Fans
July 31, 2007, 14:08:41 pm »
I prefer the gray ones. They tend to cook easier.
simon uk
Re: Squirrel Fans
August 01, 2007, 10:39:14 am »
Hey guys, can these be used on a street car?
Si.
Re: Squirrel Fans
August 01, 2007, 12:44:31 pm »
Quote from: simon uk on August 01, 2007, 10:39:14 am
Si.
I ran Fans on my street car I installed two collars on the back of the fan shroud with the fans mounted inside on the firewall with a short hose going from the fan to the back of the housing that way you can race with the belt off and use the fans, only one draw back with this set up you have to cap the fans off inside the car when your not using them otherwise you lose some of the cooling from your stock fan shroud it is easy to cap them off I made two 4 inch Round Metal plate's with velcro just stick them on when there not in use.. see my above post
