September 23, 2026, 10:26:02 am
| | |-+  Wich Studs to fits Fuchs on standard brake drums
Author Topic: Wich Studs to fits Fuchs on standard brake drums  (Read 5817 times)
« on: July 28, 2007, 11:44:10 am »
Hello,
I've a problem to find the right studs to bolt my Fuchs on the standard re-drill brake drums. Which one do you use? Press in or from an other car?
For the front I use the original VW that's fits well.
Thank you  Wink
Martin Greaves
10.88@128.58
« Reply #1 on: July 28, 2007, 12:36:09 pm »
Try here always very helpful
http://www.machine7.com/section.php?xSec=384&jssCart=4da6baea125092307626fbef43dca97c
« Reply #2 on: July 28, 2007, 13:27:55 pm »
Thanks you! I think I've found what I need.
henk
« Reply #3 on: July 29, 2007, 20:52:31 pm »
i use normal vw golf studs with black covers  stud shape over them  vw as well
mr. warehouse
« Reply #4 on: July 29, 2007, 21:03:43 pm »
I use press in 14mm studs and use stock Porsche lugs
