November 02, 2026, 16:49:56 pm
| | |-+  Berg bus 5-speed
Author Topic: Berg bus 5-speed  (Read 20135 times)
-Alex-
« on: October 07, 2013, 21:47:37 pm »
I'll soon get the  Berg bus 5-speed transaxle.  I'd like to get little bit info about installation and more info about transaxle etc.     There was actually a one or two great topics on a cal-look.com  about bus 5-speeds, i'v should taken word copy of them.
Has anybody else installed here the bus 5-speed?  Installation stories?  I once found few installation pics by google but now they're gone, somebody did have a nice billet flange type mount at bellhousing.
My car is 72', so it should be easier to install than to older chassis/body.
didi
« Reply #1 on: October 07, 2013, 22:30:00 pm »
Hi Alex
I've the most pictures stored from the closed Forum. Will send you next week the pictures, because i'm actualy on Holiday...
Didi
Didi - Aircooled VW
http://didivw.blogspot.com/
-Alex-
« Reply #2 on: October 07, 2013, 22:33:03 pm »
Ok, thank you very much.  You can also send them my email: alex.storskrubb@gmail.com
Mike at Rancho told that bus trans can be centered with some work, as you know, with stock berg mounts  it is 8-10mm of the center, atleast what i am told.
-Alex-
« Reply #3 on: October 08, 2013, 20:50:08 pm »
I got two documents from Al Graig from Gene Berg:
https://docs.google.com/file/d/0B2UWw5DwHFNJczNHeFEzOUVKbTA/edit?usp=drive_web
https://docs.google.com/file/d/0B2UWw5DwHFNJTHJiUXVOZnpKcTQ/edit?usp=drive_web
german_oval
« Reply #4 on: October 08, 2013, 21:13:02 pm »
Hi Alex
TheHanz has a berg bus 5-speed in his beetle built by steve's vw shop (LGK on the forum)
more info and pictures In Da Werks
http://cal-look.no/lounge/index.php/topic,2130.90.html
grt
drgouk
« Reply #5 on: October 10, 2013, 11:04:11 am »
Length is the issue, 30mm longer.
-Alex-
« Reply #6 on: October 10, 2013, 20:32:05 pm »
Ok, i have to get forward as possible - i'v been thinking and having conversations with Mike Herbert and Al Craig, there should not major problems  Smiley
I got also few pics from Mike, his Ghia with solid mounts:
Also if the berg front mount is not HD enough, i'll make something like this with 911 urethane mounts:
thehanz DVK
« Reply #7 on: October 12, 2013, 15:09:01 pm »
I did a lot off work on the torsion tube to get as close to original as possible, and The gearbox is now 5mm longer then original, but being a bus box also means it's About 10 mm to the right.
The top picture is my box build by rancho and modified by Steve , with a quaiffe and  a full alu support , he shortend the belhousing and made an alu  mount , mine is also solid mount...picture' s in my topic start on page 2
When you have questions ask  Wink
« Last Edit: October 12, 2013, 15:28:40 pm by thehanz » Logged
-Alex-
« Reply #8 on: October 12, 2013, 19:30:11 pm »
Okay, i intend to get the transaxle centered, and use rubbers/urethane mounts, even it means some engineering.       Yours is a very nice car, what hp levels with such big transaxle are you aiming?  Wink   Mine is a bit different, a true germanlooker  Grin
http://www.germanlook.net/forums/showthread.php?t=11248
I have rather longer ratios, but still shorter 3-4 gears than on stock 3.875 trans, i went with these ratios ( 3000rpm ), theoritically 250km/h is achieved at 6570rpm.
1. 3.44= 25.5 km/h
2. 1.93 = 45.5 km/h
3. 1.3 = 67.7 km/h
4. 1.00 = 88 km/h
5. 0.77 = 114.2 km/h
Stock with 3.875 r+p is this if somebody wonders:
1. 3.78= 24.8 km/h
2. 2.06 = 45.5 km/h
3. 1.26 = 74.4 km/h
4. 0.89 = 105.3 km/h
« Last Edit: October 12, 2013, 19:37:05 pm by -Alex- » Logged
thehanz DVK
« Reply #9 on: October 12, 2013, 21:46:40 pm »
The engine is 220 hp at the moment , next winter nitrous Will be added. Then around 300 hp. I think, but first get used to the car..
And your project is a Nice read lost off good stuff and engineering, like the nicky's...maybe in the future. Wink
« Last Edit: October 12, 2013, 21:55:14 pm by thehanz » Logged
didi
« Reply #10 on: October 21, 2013, 18:13:25 pm »
Hi Alex
I think you got already the pictures that you asked.
I installed the tranny with the berg solid mounts, so the engine is in offset position. As noted by drgouk, the length is the problem, not the offset.
Didi
Didi - Aircooled VW
thehanz DVK
« Reply #11 on: October 24, 2013, 16:35:42 pm »
Hi Alex
I am a little shorter in gears, all weddle..
R/p 4.57
3.33.  25 k/m.  At 3000
2.08.  40
1.50.  55
1.14.  73
.77    107
