September 23, 2026, 00:18:05 am
1776 parts - changing project
Topic: 1776 parts - changing project (Read 6067 times)
alstare84
October 16, 2013, 00:42:43 am »
Hello to all,
due project change I sell the following parts:
- scat volksracer 69mm x VW Pin, forged counterweighted & 8 dowel pin crankshaft €400
- mahle pistons 90.5 forged €380
- scat C35 cam + gear + scat lifters + schadek oil pump 26mm (don't sell separately because they must work together) €210
- scat hi-rev pro-strett pushrods €50
- scat I-beam connecting rods arp2000 €200
- forged 4340 flywheel lightened €200
- scat flywheel gland nut €35
- kit full flow €50
- SCAT 1-1/2" Quart Oil Sump €75
- chromoly 4140 case 10mm studs €50
- stage 1 kennedy pressure plate €150
- 1.25 pro-comp forged 4340 rocker arms €325
- power pulley kit black €50
- 043 Steve Tims heads, vw mexican heads, 90.5 bored, 40x35,
Stainless Steel valves, dual valve springs and Chromoly retainers €925
All the parts are new and still in box (some of them just opened for checking).
Only the pressure plate has only 20km. I removed after a test because I had an oil leak from crankshaft seal in my temporary 1300 immediately after the installation and with all parts original I changed idea and preferred to putt a normal pressure plate.
For any questions just ask! I can make pictures of the parts requested.
Parts are located in Germany and I can ship everywhere in Europe.
Roberto
edit: splitted parts and added prices
edit #2: some parts sold, changed some prices
Last Edit: March 19, 2014, 22:38:24 pm by alstare84
"Straights are for Fast Cars... Corners are for Fast Drivers!"
'60 Ragtop L436 Indigo Blue
'65 Sedan L87 Pearl Weiss
Speed-demon
Re: 1776 parts - changing project
October 16, 2013, 07:52:24 am »
Let me know if you want to sell the heads separately.
alstare84
October 16, 2013, 10:12:33 am »
Ok, I will wait a little bit and then I decide.
Roberto
Torgeir Schibevaag
Global Moderator
October 16, 2013, 10:27:19 am »
Might be interested in some of the other part if you decide to part it out...
Speed-demon
October 17, 2013, 08:06:29 am »
Quote from: Speed-demon on October 16, 2013, 07:52:24 am
I would be intrested in the heads, pushrods, cam+gear, and oil sump. BR Jens Kritian, Norway
alstare84
October 17, 2013, 09:31:31 am »
Ok guys,
I decided to part it out (at the end it's the best and faster solution).
Give to me a couple of days to define the prices and I will update the post.
Thanks a lot
Roberto
alstare84
October 20, 2013, 21:25:55 pm »
Parts splitted and added prices.
Roberto
alstare84
March 19, 2014, 22:38:45 pm »
spillo491
March 21, 2014, 08:42:48 am »
Which is your project Roberto ?
alstare84
March 22, 2014, 16:08:34 pm »
maybe a middle tuned 1600 with single central progressive. still in planning... too many projects in this moment
