September 20, 2026, 08:35:32 am
352309 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  Fire Extinguisher
Author Topic: Fire Extinguisher  (Read 9530 times)
RichardinNZ
« on: October 19, 2013, 10:09:55 am »
Where have people mounted a fire extinguisher  in a Beetle?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
glenn
« Reply #1 on: October 19, 2013, 11:39:48 am »
Glenn
www.DasVolks.com
Long Island's Aircooled Club
RichardinNZ
« Reply #2 on: October 20, 2013, 07:10:21 am »
Thanks Glenn. However I may need to revise my question.....where have people mounted a fire extinguisher in a Beetle with a full interior?!
Dual Carb 36hp
typ34vienna
« Reply #3 on: October 20, 2013, 17:54:43 pm »
My one is mounted behind the drivers seat:
« Reply #4 on: October 20, 2013, 18:15:24 pm »
I mounted mine under the dash to the right of the steering column.
kingsburgphil
« Reply #5 on: October 20, 2013, 22:26:00 pm »
I use a Hadron bottle...just in case.
Straight Time
« Reply #6 on: October 21, 2013, 17:04:46 pm »
Probably stating the obvious, but when deciding make sure it is accessible quickly .
If you need it , don't want to be fumbling around   Cool
No retreat, No surrender !
banditina
« Reply #7 on: October 26, 2013, 17:05:17 pm »
http://stinkingass.blogspot.it/search?updated-max=2010-09-08T23:25:00%2B02:00&max-results=20&reverse-paginate=true
www.stinkingass.blogspot.com
steve_pugh
« Reply #8 on: October 26, 2013, 23:32:50 pm »
I used to have a small one mounted on top of the tunnel just in front of the gearstick.
benlawrence
« Reply #9 on: October 27, 2013, 00:09:14 am »
i cant tell you how much i value a fire extinguisher, i was at spa in the early 2000's ( possibly late 90's) my memory has left me, i was crewing for pete bennet in bugster ( crewing being a loose terminology) Tongue  We were standing at the top of the pitlane wall where the end of the 8th mile is, a bug sponsored by udo becker ( or perhaps his own car) threw all of its internals out of bed and an engine fire ensued there was no extinguisher in the car and the driver watched as his car took fire , we ran to the garage to grab a fire extinguisher but the pit was almost down near the startline ( bottom of eau rouge) i was going to the nearest racers screaming for an extinguisher, by the time we'd got back the fire crew were on hand, however if the car had an extinguisher on board, less stuff would have got burnt, i never forget picking up hot bits of destroyed engine off the track.  Sad every vw ive had since that day has always carried an extinguisher.
steve_pugh
« Reply #10 on: October 27, 2013, 15:14:37 pm »
I'm pretty sure MSA regs don't allow for an on board extinguisher.   That's why I had to take mine out.
henk
« Reply #11 on: October 27, 2013, 17:45:50 pm »
maybe it feel confident to have a fire extinguiser with you.
but a 1 kilo extinguiser there is not much you can do or you have to be very quick there as soon as the fire starts
or yiu have to know what you are doiing.
henk!!!
mg
« Reply #12 on: October 27, 2013, 18:27:57 pm »
An on board system would be the best for fire supression.
All 3 of my race cars use a system similar to this.
https://www.pegasusautoracing.com/productdetails.asp?RecID=5624
Still having a hand held is important when a heat soaked race car ends up parked on dry grass.
When the car's very hot low slung headers and brakes start a grass fire under the car then use the hand held.
For quick access I would mount it on the floor under the driver's legs close to the seat base.
