September 24, 2026, 03:56:39 am
| | |-+  genuine 4" centerlines, stock width beam?
Author Topic: genuine 4" centerlines, stock width beam?  (Read 5469 times)
beetletom
« on: October 24, 2013, 11:41:27 am »
hi, on my 63 i have refitted a stock width beam  Kiss
it has csp disc brakes, with the bolt on caliper mounts
so now the wheels and tyres are flush with the wing lips, but i want to run wider tyres! (it currently runs 145/65's, i nearly crashed my old 71 many times in the wet with these on!!)
would it be better to go for a pair of zero offset centrelines upfront? did they make any with wider backspacing? or only 4" wide aswell?
as i want to run atleast a 165 wide tyre
« Reply #1 on: October 24, 2013, 15:15:56 pm »
That combination will not fit. Unless you like fender brakes. The offset wheels will help but you most likely have to space them out around a half inch to clear the calipers.
beetletom
« Reply #2 on: October 24, 2013, 17:14:12 pm »
ah Sad
i sold my narrowed beam, because i didn't want it tucked, and now i will have the opposite problem!! oh dear...
« Reply #3 on: October 24, 2013, 20:54:35 pm »
Need 3.5" bubble Centerlines.
axam48ida
« Reply #4 on: October 25, 2013, 07:41:13 am »
I have been running the 165's on my bubble fronts .....no problems. with your CSP kit it still may not work.
unless the kit is a zero offset kit. but you may need a 1/4 spacer to clear the caliper.
thehanz DVK
« Reply #5 on: October 25, 2013, 17:34:25 pm »
Bubble centerline's hit the calipers from the csp brake's ...so you need to use spacers  , that won't work to get the wheels in.
My car Has the Same upset only with the 2,5 inch narrowed beam...
UltraOrange67-2443
« Reply #6 on: October 26, 2013, 07:42:45 am »
The 5" Centerline is available with a better offset than the 4", 2"BS.
11 5503 580
15.0 x 5.0 hi-polish finish
3-3/8" BS
The 3.5" bubble will not clear your caliper without a spacer.
I had Neal discs and still had to run a spacer & clear the caliper.
1967 1200 2920cc EFI
