November 02, 2026, 16:43:05 pm
| | |-+  Trannie time
Author Topic: Trannie time  (Read 14144 times)
mr horsepower
« on: October 27, 2013, 12:44:39 pm »
I still have them 3 trannie s laying around at home  .
Winter is coming and now is the time to get them build.
The first is a new autocraft case with strait cut gearing and a quaiffe diff 4,12r/p vertigate shift
The 2nd is a new rhino case that wil get a 3.44 r/p weddle gearing superdiff  en lots of other goodies
The 3th stock case superdiff  steel forks timken upgrade 3.78 first pro geared and stuff
I wil take pics as i am working on them no smokecurtin here.
I hope you enjoy and we can learn
Gr henri
« Reply #1 on: October 27, 2013, 14:07:49 pm »
Gr henri
Yes please!   Grin
dragvw2180
« Reply #2 on: October 27, 2013, 14:17:44 pm »
 IS this a " NEW " production run of the Autocraft case and gear carrier ?  I ask because I have already done this build.
                    Mike McCarthy
Jesse Wens
« Reply #3 on: October 27, 2013, 16:32:42 pm »
Cool Henri,
You've allready learned me a lot so I'm looking forward to this.
Jesse
mr horsepower
« Reply #4 on: October 27, 2013, 16:49:56 pm »
Thanks jesse.
here is a pic of the autocraft incl parts involved.
gr
mr horsepower
« Reply #5 on: October 27, 2013, 16:53:45 pm »
Here i am pressing the new pinion bearing on to the weddle 4,44 pinionshaft
That will go on the rhino case.
mr horsepower
« Reply #6 on: October 27, 2013, 16:57:26 pm »
Now i gently warming the case to slide the shaft inc a 1mm shim  in the case .
torqued it then checked the preload of the bearing .
« Last Edit: October 27, 2013, 17:06:31 pm by mr horsepower » Logged
mr horsepower
« Reply #7 on: October 27, 2013, 17:16:58 pm »
Weddle told me to do a patern run out on the r/p and start with 1 1mm shim so no pinion depth measurement here .
next to do is find the carrier size and setting it with the correct preload .
To do this i use special tools and gagets.
first  thing is measure the total play.
That was 7,3 mm
so next adding shims and checking the preload of -0.10 mm
i use a dummy carrier and bearings for that
this operation is only to check and set the pinion depth
mr horsepower
« Reply #8 on: October 27, 2013, 17:28:17 pm »
After adding the rigth shimpack and checked carrier spinning i removed the carrier again and took some  shims off the opposite ring gear side
so i can slide the ring gear towards the pinion and take the measurements for correct backlash
i heated the ring gear in hot water and placed it over the carier my little one wanted to know how a torque wrench worked so she torqued the bolts.
next i started to measure the backlash
to do that put the tool back in again an began to set i up the sopper and bearing at the end of the shaft .
mr horsepower
« Reply #9 on: October 27, 2013, 17:34:06 pm »
more parts that wil go in this trannie
next time i wil run the patern to see if it is correct
for my there is only one way to do it and that is correct.
gr henri
« Reply #10 on: October 27, 2013, 20:15:40 pm »
nice to see how it is all done. thank you
mychatype3
« Reply #11 on: October 27, 2013, 21:14:57 pm »
Looking good Hen  Wink will keep contact  Grin
1968 fastback "in resto"
1970 Westfalia from the States
mr horsepower
« Reply #12 on: November 02, 2013, 19:12:38 pm »
Getting geared up for tommorows job.
gr henri
morkrieger
« Reply #13 on: November 02, 2013, 20:03:04 pm »
 Grin 7 speed typ1 transaxle? with a splitter?  Grin
mr horsepower
« Reply #14 on: November 02, 2013, 21:16:08 pm »
Last week i did some patern runs on the weddle 3.44 that goes in to the rhino case.
tryed a few different shim set up s every time you change the pinion depth also have to correct the backlash as wel
Its a pretty time consuming handling .
But i am pleased with the result .
this is with the 0.70 shim under the pinion
mr horsepower
« Reply #15 on: November 02, 2013, 21:18:45 pm »
I was not happy whit that result
it was a little heavy on the toe for met
So i changed the shim to a 0.60
And adjusted the backlash again and this is the result.
.gr
« Last Edit: November 02, 2013, 21:21:20 pm by mr horsepower » Logged
mr horsepower
« Reply #16 on: November 02, 2013, 21:30:36 pm »
Just said goodknight to my little gears
Tommorow is wake up time again..
gr
Jesse Wens
« Reply #17 on: November 04, 2013, 11:37:52 am »
keep the pictures coming  Wink
Kiel
« Reply #18 on: November 14, 2013, 22:52:02 pm »
opdate ::::::::::::::::::::::::::: Wink Wink
mr horsepower
« Reply #19 on: November 15, 2013, 18:30:41 pm »
Very bussy at work
At the moment
The next thing to do is to machine the 3.78 shaft and instal a hard woodruf key
To fit the weddle gears.
I will post pics of the machine work thats involved
gr
« Last Edit: November 15, 2013, 21:49:15 pm by mr horsepower » Logged
