October 17, 2026, 09:52:49 am
| |-+  For sale!
| | |-+  Remmele Engine Typ 4
Author Topic: Remmele Engine Typ 4  (Read 2719 times)
blasemaus
« on: November 18, 2013, 11:10:47 am »
Type 4 engine with Remmele special cylinder heads
2.9 liters
Motor housing with 105mm special pistons and cylinders
84 mm stroke crankshaft
H-Beam Conrod 5.5
Piston cooling
Pauter cam 322
Degree camshaft toothed
Bearing set (main and connecting rod bearings camshaft ) letzes new year
Special flywheel bolts
Enhanced oil pump + auxiliary spring
Oil sump extension
Aluminum pulley
Oil Pressure Switch
Oil Filler steel
Remmele special cylinder heads , 105 mm bore
Titanium intake valve 50 mm, 42 mm titanium exhaust with beryllium Ventielsitzen
11:1 compression
Reinforced valve springs Remmele
rocker
Alternators run deep milled for long hood
vent connection
Aluminum pushrods Wilke
Valve adjustment with ball foot Mercedes
Aluventildeckel Remmele with exhaust ports
Cylinder studs Longer
Pushrod tubes longer execution
Clutch Pressure Plate 200mm
Drive plate 200 mm
Engine was completely overhauled last year . Not yet been made 200 km
Torque about 310 Nm at 5300 rpm. approx 260-265 hp
V.B. 9500 EUR
papysss
« Reply #1 on: November 22, 2013, 13:24:40 pm »
pics..............HuhHuh
