October 13, 2026, 21:29:43 pm
| | |-+  Ignition Lead Tubes - Variation for performance leads
Author Topic: Ignition Lead Tubes - Variation for performance leads  (Read 3702 times)
Deanodynosaurs
« on: November 21, 2013, 16:51:50 pm »
Hi all,
I'm trying to tidy my engine bay up, an one thing I really want to neaten up up is the ignition leads.
I know the leads need to be kept apart as current can jump across leads, and I have used the proper MSD lead separators, which are attached to a bar running across the fanshroud (i.e. a variation on the tube). However, being a steel bar, is the current just going to find a easy route through the bar if it does jump? I.e. the same as not separating them?
Any comments much appreciated.
Dude  Cool
« Reply #1 on: November 22, 2013, 13:57:43 pm »
Why not use a piece of plastic bar instead of the steel one in the picture?
Lee
Deanodynosaurs
« Reply #2 on: November 22, 2013, 14:17:43 pm »
Lee
Hi Lee,
Good idea. Smiley I hadn't thought of that, and that should be OK as i can still insert riv nuts in it as well. Smiley
However, i think i might have come up with a simpler solution that does away with the tube all together. Basically some 's' shaped brackets mounted to the fan tin and thermostat tin wear screws. I'll have a play and see what i can come up with this weekend.
Dude  Cool
