September 23, 2026, 17:02:32 pm
| |-+  Wanted
| | |-+  Original non GT Empi Rocker Cover hardware
Author Topic: Original non GT Empi Rocker Cover hardware  (Read 3857 times)
smurf67
« on: November 22, 2013, 14:30:49 pm »
Hi was wondering if any one knows if reproduction hardware is available for original Empi rocker covers or have you had any success with making a suitable substitute. All help would be appreciated.
Cheers Alex
« Reply #1 on: November 22, 2013, 17:29:45 pm »
Oil cooler seals is the only alternative I know of.
smurf67
« Reply #2 on: November 22, 2013, 18:03:38 pm »
Cheers Zach will look into that, can just your typical of the shelf rocker cover bolts etc then be used, its just I have none of the hardware at minute but sure I have some cheap fitting kit somewhere I can pinch the bolts from if they would work? Thanks again Alex
« Reply #3 on: November 23, 2013, 12:27:20 pm »
Pretty sure that's all it takes, I haven't tried it myself to be honest. I believe it's the early type seal you need.
