October 13, 2026, 00:01:45 am
Weight of the wheels we use
Topic: Weight of the wheels we use (Read 27502 times)
November 24, 2013, 21:26:57 pm »
Hi,
Is there a list of the weight of the wheels we use.
I know there is a list of genuine Porsche wheels somewhere on the net.
But how about the aftermarket wheel, steel rims and the rest..
Kind of interesting to know what the lightest wheel is.
Re: Weight of the wheels we use
November 24, 2013, 21:49:51 pm »
My guesstimate
Erco race weight or DDS[ real close], Erco street weight,real BRM[I think 7lbs], Real Gas burner[I think 9.5 lbs] Real fuch [ 20 something lbs ? ]
Maybe someone can add centerlines, bogarts, etc. Don't bother about the fakes or replicas though, they are just to heavy
Steels are just as bad
neil68
November 24, 2013, 22:27:43 pm »
My CMS street weight 6" rear wheels weigh 4 kg and my Bogart 3.5" fronts are 3.6 kg.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
Turbo_Rich
November 24, 2013, 23:33:14 pm »
I would love to know what the weight of my replica Gas Burners are. They seem really heavy in comparison to my 16" genuine Fuchs. I really want to use the Fuchs but the 16" changes the tyre side wall options meaning there may not be as much give. However the weight saving may help gain that critical tenth or two!
November 24, 2013, 23:38:24 pm »
John Connolly has been kind enough to list some weights for us.
http://vwparts.aircooled.net/VW-Wheels-s/117.htm?searching=Y&sort=1&cat=117&show=50&page=1
There are a couple I've weighed, Pg.23 of "weight-saving" thread.
Fonz
Still struggling with speed humps!
December 03, 2013, 13:00:42 pm »
Quote from: richie on November 24, 2013, 21:49:51 pm
You'd be surprised.
Here are some weights of various width original 15" Fuchs that someone took....
4.5 - 10 lbs. 12.8 oz. (no date) without valve stem, orig. anodized, clean backside
4.5 - 10 lbs. 13.4 oz. (no date) without valve stem, orig. anodized, clean backside
5.5 - 11 lbs. 10.0 oz. (Apr '68) with valve stem, polished & painted, dirty backside
5.5 - 11 lbs. 12.4 oz. (Apr '68) with valve stem, polished & painted, dirty backside
6.0 - 12 lbs. 7.6 oz. (Jan '70) with valve stem, orig. anodized, dirty backside, with flare
6.0 - 12 lbs. 6.0 oz. (Jan '70) with valve stem, orig. anodized, dirty backside, with flare
6.0 - 12 lbs. 4.4 oz. (Jan '70) with valve stem, orig. anodized, dirty backside with flare
6.0 - 12 lbs. 2.4 oz. (Jan '70) with valve stem, orig. anodized, dirty backside with flare
7R - 12 lbs. 12.7 oz. (June '69) with valve stem, polished & painted, dirty backside
7R - 12 lbs. 6.5 oz. (June '70) with valve stem, polished & painted, dirty backside
Mike Maize
December 06, 2013, 12:19:25 pm »
I know years ago when I got my 4.5's the box was so small and light I thought they only sent one wheel!
December 07, 2013, 13:41:37 pm »
Quote from: Fonz on December 03, 2013, 13:00:42 pm
You'd be surprised.
You made me wonder so I did some weighing just now with what I have here
Late 6x15 12 1/4 lbs
5.5x 14 11lbs
and a real gasburner 10lbs not a huge gain
December 07, 2013, 15:55:23 pm »
Quote from: richie on December 07, 2013, 13:41:37 pm
5.5x 14 11lbs
Good to know, got some of those in my shed. Thanks for the info.
Phil West
December 09, 2013, 08:10:52 am »
Quote from: Eddie on November 24, 2013, 21:26:57 pm
Hi,
My race weight ercos weigh in at:
3.5" 2,390gm or 5.3lbs
6" 2,589gm or 5.7lb
Phil
December 09, 2013, 08:29:34 am »
Quote from: Phil West on December 09, 2013, 08:10:52 am
Hi,
6" 2,589gm or 5.7lb
Phil
Do you have more spec on these? ET? 5x205 or 4/5x130? (big or small hole in the middle
Phil West
December 09, 2013, 09:00:35 am »
Quote from: Erlend / bug66 on December 09, 2013, 08:29:34 am
Hi,
6" 2,589gm or 5.7lb
Phil
Wide 5. Not sure what you mean by ET on a wheel?
December 09, 2013, 10:08:11 am »
Offset. I guess the wide 5 is a little lighter than 4x130 or 5x130.
Did you custom order?
Phil West
December 09, 2013, 11:41:13 am »
Quote from: Erlend / bug66 on December 09, 2013, 10:08:11 am
No they were standard size, had them a while, they are the full inset 3.5" and standard 6" which from memory was 2"/4"
Iryanu
December 09, 2013, 17:55:59 pm »
Porsche 911 Fuchs Forged 16x6 17lbs 7.71kg
Porsche 911 Fuchs Forged 16x7 18lbs 8.16kg
Porsche 911 Fuchs Forged 16x8 19lbs 8.61kg
Porsche 911 Fuchs Forged 16x9 20lbs 9.07kg
Porsche 914 Mahle Forged Mg 15x5.5 10lbs 4.53kg
Centerline Auto-drag (4x130) 15x3.5 11lbs 4.98kg
I have a spreadsheet with over 4400 wheels with their weights if anyone want's it. Not much old stuff in there though. Only ones of interest are above. Few Welds, few centerlines, lots of bbs and a heap of tuner stuff.
December 09, 2013, 18:39:56 pm »
Quote from: Iryanu on December 09, 2013, 17:55:59 pm
Is that the 4 lug 914 wheel or the 5 lug 914/6 "gas burner" as that is pretty light if its the 4 lug
volkskris
December 09, 2013, 22:18:03 pm »
You'd be surprised.
4.90kg
4.92kg
5.27kg
5.34kg
5.66kg
5.61kg
5.57kg
5.51kg
5.80kg
5.63kg
For people who use a normal system
Iryanu
December 09, 2013, 23:43:17 pm »
Quote from: richie on December 09, 2013, 18:39:56 pm
Full description in the sheet was as follows:
Porsche 914 6-cylinder 5-bolt Mahle (rare)
December 10, 2013, 09:08:04 am »
Quote from: Iryanu on December 09, 2013, 23:43:17 pm
Thankyou , that makes sense as my wheels weighed about that
December 10, 2013, 10:35:32 am »
the 4 lug is much heavier. i held them in hand yesterday, need to weigh them.
Iryanu
December 10, 2013, 13:31:55 pm »
Found another in my sheet doesn't say to which version of the EMPI 5 but I'm assuming a reproduction not one of those fancy 2 piecers.
EMPI 5-spoke Cast 15x5.5 20lbs 9.07kg
Last Edit: December 10, 2013, 13:36:41 pm by Iryanu
Turbo_Rich
December 10, 2013, 20:09:10 pm »
Wow looking at the details here for the 16" Porsche Fuchs (17lbs-7.71kg & 18lbs 8.16kg) and guessing my gas burner reps are about 22lbs (9.97kg) each means that thats a 5lbs or 2.26 kg saving on each front and 4lbs or 1.81kg each at the back.
So 19.92 lbs or 9.04 kg saving overall although I guess the extra weight of the tyres may negate that saving down?
December 10, 2013, 21:13:56 pm »
Tyres can be the same weight saving too.
2 tyres the same size can be different by as much as 10%-15% each, eg. 195/75R14, Hankook's are 1.3kg lighter than Bridgestone's.
BIG difference in unsprung weight.
December 10, 2013, 21:39:20 pm »
Quote from: modnrod on December 10, 2013, 21:13:56 pm
Agreed, the tall profile we like for that traditional Cal looker makes it even worse, I have weighed several brands of front runners for our race cars to get the lightest in the size we need
dannyboy
December 10, 2013, 23:47:17 pm »
Quote from: richie on December 10, 2013, 21:39:20 pm
i couldnt believe how much more a phoenix slick weighed than mh slick ......but phoenix slicks look cooler
... i went for the lighter ones
8.77@156.8mph
O/FF 60
Turbo_Rich
December 21, 2013, 15:39:01 pm »
Finally got round to weighing my wheels,
the Porsche Fuchs 16" x 7 with 205/50/16 , 16" x 6 with 205/45/16 both come out at 15kg/33lbs each with the tyres.
The Gas burner reps 15" x 5.5 with 205/65/15 rear comes in at just under 17kg/37.47lbs
the front with 185/60/15 come in at 16.5kg/36.37
1 205/60/15 tyre came in at 8.5kg/18.73lbs
So if I switched to my Fuchs I would save about 4kg/8.81lbs at the rear, 3kg/6.61lbs front total of 7kg/15.43lbs. Probably not a big enough gain to justify the expense, hassle and change in tyre profile?
xbacax
August 11, 2014, 19:31:51 pm »
Could someone please tell me, how much those Centerlines replicas weight ??
http://www.fotosik.pl/pokaz_obrazek/b852a6020a18c055.html
ALB
August 11, 2014, 22:55:45 pm »
Quote from: Turbo_Rich on December 10, 2013, 20:09:10 pm
I know those weights for the 16 x 6's, 7's and 8's are on the Porsche Wheel weights page as 17, 18 and 19 lbs, but a friend on SOC weighed some 16 x 6's and 7's he had and they were only a pound and an ounce or 2 more than the same width 15" Fuchs. I'm not arguing with or doubting you; only telling you what someone told me. The 15 x 6 and 15 x 7 Fuchs I have weigh in at 12 and almost 13 lbs. Al
August 12, 2014, 17:59:52 pm »
Quote from: xbacax on August 11, 2014, 19:31:51 pm
If those are the ones I think they are, they are cast aluminum and not light like Centerlines are.
xbacax
August 12, 2014, 22:24:05 pm »
Quote from: Rick Meredith on August 12, 2014, 17:59:52 pm
well those are replicas, and I know that they're not the same weight as originals, probably not even close, but I'd still like to know how much do they weight
I kinda like those wheels
