September 23, 2026, 22:29:37 pm
| | |-+  Empi 5 Spoke Centre Caps?
Author Topic: Empi 5 Spoke Centre Caps?  (Read 12892 times)
Azureblue52
« on: August 03, 2007, 09:06:51 am »
Hi Everyone,
I need to get a couple of sets of Empi 5 spoke center caps and stickers. They're for genuine wheels, but repro caps. It would be helpfull if they're in the UK but not essential, can anyone help?
David
« Reply #1 on: August 03, 2007, 09:18:10 am »
try either Java or KK, they both sell repo centre caps.
jick
« Reply #2 on: August 03, 2007, 14:35:29 pm »
 i have a set of 4 new reproduction stickers to go on the original style caps,
the orange/red type with the empi gt logo.
i paid $25.00 for them
so, yours for £12.50 free postage if you want......i'm in London.
cheers...jick
Azureblue52
« Reply #3 on: August 03, 2007, 18:09:09 pm »
Thanks for the help guys. KK haven't had any for ages, but I'll try Java.
Jick, I'll take those stickers. Can I send you a cheque or paypal?
David
jick
« Reply #4 on: August 03, 2007, 18:20:39 pm »
hey dude...paypal will be probably be easiest, send it to :
james@magnumpr.co.uk
cheers mate,
if you PM me your address i'll get them sent out tommorow.
here's how they look... Grin
Azureblue52
« Reply #5 on: August 03, 2007, 19:12:56 pm »
Hi Jick,
Payment sent.
They're the ones, just need to get the caps now. They look great with the caps fitted, lug nuts and everything.
Did you need to use a spacer to clear the 356B drum?
David
jick
« Reply #6 on: August 03, 2007, 19:30:33 pm »
hey David,
cheers dude!
i'll get them posted in the morning.
no spacer needed to clear the drum, i think its only the torque thrusts that have problems.
cheers...jick
« Reply #7 on: August 03, 2007, 19:37:44 pm »
with the 356A drums you add a spacer(8mm) or you broke your spoke , I know what I say I had joke  Angry now i'had crack on my wheels , now with the B drums i don't know if you've to add spacer  Huh
rgd
fabian
jick
« Reply #8 on: August 03, 2007, 20:41:06 pm »
they're only just mocked up... i haven't got them properly assembled yet, and it doesn't seem like they need spacers, although with that info Fabian,  i'll make sure i take a really close look at them when i come to torque them up.
« Reply #9 on: August 03, 2007, 21:34:49 pm »
behind the spoke there"s a lips and this lips touch the brake if you don't have spacer i will post a picture of my empi 5 with the spacer
« Last Edit: August 04, 2007, 13:37:14 pm by speedwell » Logged
Azureblue52
« Reply #10 on: August 03, 2007, 23:17:54 pm »
An 8mm spacer isn't too bad. I thought the nuts that bolt the wheel halves together caused the problem more than the strengthening webs? I'll try fitting a set up to my 356 drums tomorrow.
David
beetletom
« Reply #11 on: August 04, 2007, 08:06:29 am »
whoa!
after seeing the back of my split rim empi 8, i thought they were fragile!
but the 5's see much more fragile, 1 bolt per spoke, but they are spread far apart, unlike the 8 spoke wheel.
Azureblue52
« Reply #12 on: August 04, 2007, 09:37:08 am »
The bolt isn't the reason why the Empi 5's crack. It's because where the back of the wheel fit's to the front, the front has a rectangular cut out with square edges. This produced a stress raiser in the worst possible place, hence they crack across from both sides of each spoke. The early ones quite often cracked (not always thought), but the later version with more strengthening ribs and BRM style lug Top Hats don't crack at all. I'll take some photo's if you like because I've got both versions.
Fabian, I love the wheel and tyre combo on your car, what tyre sizes are you using?
David
« Reply #13 on: August 04, 2007, 09:48:37 am »
michelin xzx 145/15 at front & bridgestone sf 312 215/65/15 at rear but i would change the rear by an smaller size like 185/70/15 in vredestein classic because i 've  a 1200cc engine  there isn't a lot of horse power , but i've a lot of donkey power Grin   Grin
rgd
fabian
« Reply #14 on: August 04, 2007, 13:13:04 pm »
here 're some better pictures from the space between the drums & the lips (empi5) ,
« Reply #15 on: August 04, 2007, 13:33:36 pm »
here's the spacer i use  ,it's an aftermarket spacer you can find in every vw shop  and after it is necessary to make it machine so that there remain only 8mm less otherwise that gets Shocked
black_bullitt
« Reply #16 on: August 06, 2007, 13:59:37 pm »
You still have to use spacers if you run 356B drums too, 8mm sounds about right.
« Reply #17 on: August 06, 2007, 14:36:03 pm »
cool info  Wink
