November 04, 2026, 14:09:57 pm
| | |-+  Dellorto 40 DRLA and manifold question
Author Topic: Dellorto 40 DRLA and manifold question  (Read 6320 times)
Nikov
« on: December 05, 2013, 11:54:54 am »
I have a pair of 40's and manifolds, the query I have is; the carbs are 40mm where they meet the manifold but the manifold throat is 48mm which results in a sizeable step.
Do I need manifolds that flow smoothly from the carb or will these ones be ok?  Huh
« Reply #1 on: December 05, 2013, 13:23:03 pm »
matching manifolds would be best. these will create a pocket where the air/fuel mixture could stall.
Nikov
« Reply #2 on: December 05, 2013, 13:59:01 pm »
Yeah that's what concerns me Nicholas  Sad
« Reply #3 on: December 05, 2013, 14:44:11 pm »
The difference is very minor.
Some people claim the intake vacum at idle gets too low with the larger manifold. I use to say that if they have this problem something else is the matter. I have used these manifolds right down to 1200 cc. and have only noticed a slight hesitation off idle when large duratrion cams are used too.
Nikov
« Reply #4 on: December 06, 2013, 12:00:27 pm »
I'll give them a go and see what happens.
« Reply #5 on: December 06, 2013, 14:06:43 pm »
There were specific 40mm manifolds made back in the day. Hard to find, but they're out there...
Jesse Wens
« Reply #6 on: December 06, 2013, 15:03:48 pm »
you can get new ones at CSP
http://www.csp-shop.com/cgi-bin/cshop2/front/shop_main.cgi?func=det&wkid=77828856538&rub1=Engine&rub2=Fuel%20System%2CIntake%20Manifolds%2CIntake%20Manifolds%20Type%2D1&artnr=19845a&pn=0&sort=0&all=
I, ve used them also because the step seemed rediculous to me.
Jesse
Garrick Clark
« Reply #7 on: December 07, 2013, 16:15:16 pm »
I'm using some of the 40mm  CSP manifolds to match the 40mm dells.
They are worth buying.
Air cooled Engine builder
markvo
« Reply #8 on: December 26, 2013, 06:54:52 am »
You can use Gene Berg 40 idf manifolds
