November 03, 2026, 00:33:32 am
| | |-+  Flanged crank adaptor bearing
Author Topic: Flanged crank adaptor bearing  (Read 16939 times)
danny714
« on: December 06, 2013, 23:16:43 pm »
Trying to find out what the type 4 main into a type 1 line bore adaptor bearing actually is ? Anybody know . Part no's etc .
Reichspeed aircooled 0774 830 7137
Reichspeed.com
Vwdrc pro sponsor 2012
facebook - Reichspeed aircooled
« Reply #1 on: December 07, 2013, 00:33:35 am »
It's a modified/narrowed BMW piece.
Not sure of the Beemer engine model ...
TxT
dangerous
« Reply #2 on: December 07, 2013, 03:32:01 am »
these are the ones I have been using:
http://www.precisionintl.com/Stock.aspx?Code=EB4768M7000GY&EID=327
 The thrust will have to be sorted too,
and for this I machine the case for a To#¤ta 3RZ thrust washer set.
danny714
« Reply #3 on: December 07, 2013, 08:46:06 am »
Thanks . The case would just need cutting for the bearing tangs with those then ?  Guessing that's a centre thrust setup .
Reichspeed.com
« Reply #4 on: December 07, 2013, 13:41:47 pm »
On my last engine i modyfied the original BMW thrust bearing too . works nice and you can only change the inner bearing for freshnup
danny714
« Reply #5 on: December 07, 2013, 16:42:03 pm »
Which thrust bearing was used ? What mods did you have to do ?
Reichspeed.com
« Reply #6 on: December 07, 2013, 17:59:36 pm »
Looks like this , original BMW bearing cut to the right size and the thrust is bolted to the case . but is expensive
danny714
« Reply #7 on: December 07, 2013, 20:14:51 pm »
Is this one complete set of bearings with only the thrust bearing modified ? Guessing it still uses the standard T1 small nose bearing ?
Reichspeed.com
« Reply #8 on: December 07, 2013, 22:23:09 pm »
Hi Danny
it does use the vw bearing on the nose, all the BMW bearings are modified/narrowed, that isn't affected by what you do for thrust
danny714
« Reply #9 on: December 07, 2013, 22:47:08 pm »
Cheers Richie , clears that up. Is this the better way to go in terms of bearings etc ?
Reichspeed.com
« Reply #10 on: December 07, 2013, 23:20:31 pm »
Yep, works real good, bearing quality is 100 times better, only issue is there are no oversize bearings available for the outsize if the case ever needs align bore, but you can save it by going to T4 align bore and doing something similar with the type 4 center split bearing and using it in the main 3 bearing journals. I have built them both ways and have the thrust done for me, I have had center thrust, rear thrust and [double] thrust on both middle and rear/flywheel end for a real heavy clutch set up and they all worked real well.
I keep the modified narrowed bearings if ever you need any
danny714
« Reply #11 on: December 08, 2013, 10:35:57 am »
Does that set include the thrust bearings ? Pm me with a price please Richie.
Reichspeed.com
« Reply #12 on: December 08, 2013, 10:59:34 am »
No I only have the normal bearings as I don't use the BMW thrust bearing in my set ups
PM sent
danny714
« Reply #13 on: December 08, 2013, 15:36:41 pm »
Who do you use for the machining ? Is centre thrust a better option than rear ?
Reichspeed.com
UltraOrange67-2443
« Reply #14 on: December 08, 2013, 21:42:33 pm »
I've got the BMW setup with the center thrust setup.
Shawn Geers did this one.
Sorry about the small pic.
1967 1200 2920cc EFI
« Reply #15 on: December 08, 2013, 21:49:26 pm »
Geers engineering, and the flywheel end now, there's some theories as to why the center is flawed which make sense to me
Mike Lawless
« Reply #16 on: December 08, 2013, 23:13:41 pm »
Here's another method to use BMW bearings that does not require case machining. It does however, require manufacturing thrust inserts to fit, and I've been using slotted spring pins to retain them. Once the crank is in, there's no where for them to go. I've been running this set up for the last several years. I did this because I didn't want to send my case down to southern california to get the machining done. The thrust inserts seem to average about .092" thick with will give .006 to .010" thrust clearance.
Personally, I like Udo's method. When you buy a complete set of bearings for the 530 BMW M30 engine, you get seven bearings. One is a thrust. Make a fixture to hold the bearing so that you can cut the thrust sides off and attach those to the case with small screws or even pins.
Below is a pic of mine with bronze inserts
http://lawlessdesigns.com/thrust3.jpg
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
« Reply #17 on: December 09, 2013, 22:20:11 pm »
I do not like the center thrust , the case si stressed enough with the bending of the crank so do not make other wear to it.
I never made a complete price for a set of all bearings . and you must make shure you can drill the holes and threads for the screws
Mikes is also a nice method
Shag55
Shag Leone, SL-1racing
« Reply #18 on: December 10, 2013, 16:45:31 pm »
I do the same on mine with the bronze rear bearings. Tapping the small holes is a pain in the but!! Pins should be fine but I feel if there is any thrust wear the grit can get in between the bearing and the case and possibly push out the bearing closing up the end play. I'm just paranoid I guess. Mikes has been fine.
Ps: I don't like the center thrust either. Flex Problems for both the crank and the case.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
daniel1366
« Reply #19 on: December 16, 2013, 15:00:48 pm »
Greetings to all. Hey Mike, the ID of the insert seems a little bigger than the bearing, is this correct? Thanks in advance.
Mike Lawless
« Reply #20 on: December 16, 2013, 19:30:00 pm »
Yes it is. Only slightly larger. And when you do it this way, you have to bevel it for crank radius clearance. If you make the insert ID the same or slightly larger than the OD of the bearing, you only have a couple millimeters of contact at the crank thrust. That's why I did mine the way I did. It took some time consuming finish work, but I ended up the maximum surface area for contact.
daniel1366
« Reply #21 on: December 16, 2013, 19:42:41 pm »
Thanks Mike.
danny714
« Reply #22 on: January 03, 2014, 11:33:37 am »
How are the notches being cut for the bearings tangs , woodruff cutter in a horizontal borer ?
Reichspeed.com
Mike Lawless
« Reply #23 on: January 04, 2014, 19:53:02 pm »
Careful application of a flat file on edge
daniel1366
« Reply #24 on: January 05, 2014, 00:39:55 am »
Hi Mike, question, Are the holes for the pins or screws thru holes or you have to make them from the inside and out. Don't have a case in front of me, mayby there is an oil passage in between. thank you.
danny714
« Reply #25 on: January 05, 2014, 20:21:37 pm »
Cheers Mike
Reichspeed.com
Mike Lawless
« Reply #26 on: January 07, 2014, 17:33:39 pm »
I did not make mine "thru holes"
I used a tiny right angle drill adpater for a dremel. For 1/8" spring pins, all that is needed is to drill the hole about .430 deep and use a 1/2" long spring pin. I made up a drilling fixture and I used a small set collar on the drill. A bit of work for a one shot shot deal, but for me it has paid off since I have done about a half dozen cases over the past few years, and not all were mine.
If I were going to tap the holes holes for screws (6-32 is a good size), I think I would make another fixture with the same hole pattern to keep the tap straight. And definitely use a bottoming tap to finish threading the hole
Disclaimer:
Not everyone can or should do this. It requires uncommon common sense, a high level of skill with tools, extreme patience, and the willingness to accept that you just may screw up a $600 crank case if you botch it.
That, my friends, is the basis of a good hot rodder. Some people are way better off paying to have it done.
Shag55
« Reply #27 on: January 08, 2014, 15:00:16 pm »
True that Mike!
daniel1366
« Reply #28 on: January 09, 2014, 02:28:46 am »
Thanks Mike.
