September 23, 2026, 09:19:48 am
Window and door lock regulator clean and Lube...???
Topic: Window and door lock regulator clean and Lube...??? (Read 5374 times)
Kaferdog
December 09, 2013, 09:57:48 am »
Can Anyone what works best to clean the sticky grease inside a window regulator & door lock mechanisms and what to re-grease it with ..
Re: Window and door lock regulator clean and Lube...???
December 09, 2013, 17:30:40 pm »
I used aerosol carb cleaner along with high pressure air to clean it. If it's real thick grease I use a tooth brush as well. Then used light penetrating oil (I use kroil) and dry moly powder to lube. then I mounted it my vise and used my reversible electric drill to run it up and down. Don't go to fast as you can damage it.
Martin S.
December 11, 2013, 05:14:58 am »
Recently I dealt with a sticky drivers window regulator in our 65. I thought it was the regulator and had a replacement ready to go, but most of the problem was the felt channels below the sash that weren't tight into the metal channels. There also was some tar-like ooze coming from somewhere that was gripping the glass in the channels. I managed to clean out the channels with the glass dropped down, without replacing the felts and it worked smooth enough again. The alignment of the glass is critical too.
Kaferdog
December 15, 2013, 10:58:42 am »
Thanks Guys..!...Will give both a try.!
