October 14, 2026, 17:07:20 pm
| | |-+  What H/P have you made with 48IDF's?
Author Topic: What H/P have you made with 48IDF's?  (Read 7992 times)
drgouk
« on: December 28, 2013, 00:03:59 am »
I am interested to see what kind of power you can make with a set of 48 idf's? Standard out of the box or modified.
250h/p possiable with some mods?
Back at my old job  we made 234h/p on a set of 48idfs on a 1900cc 16Valve alfa boxer, So I think they are almost there.
Let me know your experiences.
David Gouk
Taylor
« Reply #1 on: December 28, 2013, 04:11:46 am »
Was the 16 valve individual runner or plenum?
drgouk
« Reply #2 on: December 28, 2013, 05:24:35 am »
Individual runner.
Taylor
« Reply #3 on: December 28, 2013, 05:44:36 am »
That's really good.  I know 48 IDAs can make 250+ with 44 chokes.  But I don't know what the biggest choke you can fit in an idf.
« Last Edit: December 28, 2013, 05:46:50 am by Taylor » Logged
drgouk
« Reply #4 on: December 28, 2013, 05:54:49 am »
Taylor, I see Jaycee does 44 vents for the IDF. Maybe some shaft profiling and some custom stacks and you could get there.
Taylor
« Reply #5 on: December 28, 2013, 06:31:16 am »
A buddy of mine has 48 dell tri jets.   He did a good amount of work on them. Stacks, profiling and all but only has 39 or 40 chokes.  It makes 215 on pump gas and runs 11.60s.  80x94
« Reply #6 on: December 28, 2013, 10:05:32 am »
I've got 48IDFs on my 2007cc motor. I've never dyno'd it, but it did run 12.50s in a 1640lb car (with driver) with slicks and a close ratio gearbox. I'd be interested to see what difference my IDAs make.
« Reply #7 on: December 28, 2013, 15:00:23 pm »
Taylor, do you know if he changed the trijet jetting? I'm exploring that on mine now.
« Reply #8 on: December 28, 2013, 16:00:13 pm »
225 HP right here:
http://youtu.be/iFk4hdd_tG4
drgouk
« Reply #9 on: December 28, 2013, 20:57:30 pm »
225 HP right here:
BB, do you know of anyone back to backing them with IDA's?
drgouk
« Reply #10 on: August 02, 2015, 03:07:38 am »
I have purchased a set of 48idfs to see what can be made with them. I will try them on my 2789cc street motor on the dyno. My plan is to drill the float chamber for a drain, Then I can install a sight tube, like the IDA ones from Jaycee. This way I can observe whats going on in the float chambers on the engine dyno. I will install some 2.5 Viton tipped needle valves and probably radially drill them for increased flow. Any thoughts or new info would be appreciated.
