November 02, 2026, 20:09:46 pm
maico discs brake
Topic: maico discs brake (Read 25636 times)
maico discs brake
August 04, 2007, 22:57:22 pm »
suit to the topic : cal look wheels lets see yours (last page with my wheels) , I was to interest to buy the maico discs brakes
, but after several days of reflexion and put questions
, I believe that I any more will not take them (not having comfirm my purchase)
here reasons: by looking at well the disc and the flask of this one,the circumference of those one appears similar to me with the 356A porsches brakes drums and considering my problem with my brakes 356 is that I cannot put my torq trust D rims I think that the problem it would be repeated with the discs, I think that the diameter of the drum is 325mm but I don't know that of the maico, but I awaits information by jurgen which has a set on its oval (DFL KLUB)
the other reason then i can't put my torq trust D on the brakes drums is the spoke of this one she's plunges directly after the flask of or that touches the drum
here's some pictures tried to compare the maico and 356 drums thanks to allow me to see there more clearly , because I like really those one but I don't want to put money in brakes which will not go with my rims
rgd
fabian
Last Edit: August 04, 2007, 23:05:17 pm by speedwell
Re: maico discs brake
August 04, 2007, 23:04:47 pm »
and here's a little draw i made just to see what the maico represent behind the wheels , and you can see he's just behind the curve of he spoke
and with the 356 drums she touch(the spoke) at the place where the spoke start
Frank LUX
Back...Soon...hopefully!!!
August 05, 2007, 19:14:56 pm »
Hi Speedy,
Please don't get this Wrong!!!
But get your Motor rebuild and spent your monies on a Nice Engine Case, your's does not give Justice to your Car...
I personnally think that a Painted Engine Case is a Big NoNo...specially in such a nice Car!!!
Frank
Liou
August 05, 2007, 19:24:15 pm »
hey
this oval DFL
My 62 ragtop cal look
alex d
August 06, 2007, 09:59:18 am »
just throw away the 356 brakes, I'll pick them up for free
Gregor/DFL
No comment...
August 06, 2007, 10:27:39 am »
Hi! In an Old "Gute Fahrt" issue (July 1964) there was an article about the Maico´s-unfortuanetly article is only in German....
Basically conclusion is that the Maicos are not better than the standard drum brakes-they only have the advantage that they
do not have to be adjusted. Our club member Juergen runs those brakes on his Oval as mentioned-but he also states that the brakes are more "show than go"
1965 black bug with Empi 5s
Gregor/DFL
No comment...
August 06, 2007, 10:31:52 am »
another interesting detail: The Type3 shown in the article is described as "VW 1500 S, ATE experimental car running disc brakes both front and rear" (!!). Not too bad for a 1964 5x205 car...
alex d
August 06, 2007, 10:37:37 am »
cool article, now where did I put my german dictionary
BTW the type 3 disc brakes look like they don't have wide 5 pattern if you look closely
August 06, 2007, 12:15:50 pm »
I thought the main advantage with disk brakes is that you repeatedly can do hard braking without the brakes fading.
What's wrong with a painted engine case Frank?
Gregor/DFL
No comment...
August 06, 2007, 12:49:36 pm »
Quote from: JHU on August 06, 2007, 12:15:50 pm
...but if the disc has the same size like on a today´s Mountainbike, it´ll start to fade anyway
Maybe it´ll take a few seconds more as the cooling of the rotor is a bit better....
Frank LUX
August 06, 2007, 13:26:55 pm »
I don't like them...
Just my 2 Cents...
Frank
Frank LUX
August 06, 2007, 13:27:44 pm »
Quote from: Gregor/DFL on August 06, 2007, 12:49:36 pm
Frank
August 06, 2007, 14:58:02 pm »
The cooling is the trick...
empicolector
EMPI RULES
August 06, 2007, 15:35:06 pm »
hye fabian thanks for your comment on my blog
just now in the samba do it
but high price
August 06, 2007, 19:32:41 pm »
Quote from: alex d on August 06, 2007, 10:37:37 am
i think the top picture is a beetle and it has indeed a different boltpattern. the bottom one could be a 5 lug too bad they run covers otherwise we could see it better. but the type3 only had brakes on the 66 model cars starting with the fastback production. so maybe it has 5 lugs...
Rune
SCC Crew
Screwdrivers #7
August 06, 2007, 19:53:30 pm »
Quote from: Liou on August 05, 2007, 19:24:15 pm
hey
this oval DFL
Could anyone tell me the part number on the Competition Engineering 90/10 shocks Jürgen is running on his car?
August 06, 2007, 20:41:43 pm »
Freshly restored set down under
August 06, 2007, 20:56:06 pm »
mickael it's yours?? very nice , if those are yours can measure the circumference , it's to comparte with the 356 drums
thanks
jick
August 06, 2007, 21:02:31 pm »
they're not Mikes...
he only buys dash-plaques.
www.custommotorbodies.co.uk
August 06, 2007, 21:03:04 pm »
Fabian they are not mine, they have just been restored in Australia, look on the Samba for a user called "Der Steiner Rad"
August 06, 2007, 21:03:32 pm »
Quote from: jick on August 06, 2007, 21:02:31 pm
and NOS ashtrays!!!!
August 06, 2007, 21:06:41 pm »
thanks , but i can find the adds on samba
August 06, 2007, 21:14:02 pm »
i'm asking jurgen about the diameter and i've just receive the answer the rotor is 315mm and 356A brake drums is 325mm
jurgen said onthe mail :Complete Diameter is 315 mm.The Spokes of your Wheels are between the holes.There is more place.That diameter is 250 mm.The first problem is then the Brake-Caliber
August 06, 2007, 21:19:15 pm »
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=20432
Azureblue52
August 06, 2007, 21:22:12 pm »
Joe Ruiz is also selling a set with some spare discs:
http://www.thesamba.com/vw/classifieds/detail.php?id=428729
August 06, 2007, 21:37:16 pm »
thanks for the linls guys
August 06, 2007, 22:36:39 pm »
do it - do it - do it - do it
August 06, 2007, 22:46:16 pm »
If you have a big engine don't use the breaks . I drove a car that goes 12's at bitburg and it was an adventure to get the car slower after the finishline . The standart drum breaks work better !!
www.Udobeckertuning.de
simon uk
August 07, 2007, 12:13:22 pm »
As I understand it, the calipers are the same used on Maico scrambler bikes from the period, of which there are still a semi regular supply on a well known auction site. I have never seen another disc brake where the caliper sits inside the disc, they look nuts, and that australian set looks awesome. I have seen the rotors sold separately before, but it would be good to have the dimensions of the caliper mounting bracket stored on line somewhere so that people can have them custom made if they have the rotors only, and also, any markings on the caliper so they know what model number to look for
Si.
Kobus
See you at the NEXT EUROPEAN BUGIN!!! Summer 2011!
August 07, 2007, 13:50:34 pm »
i think the ATE test notchback used porsche 356 C or early 911 (901) brakes!
and check on Carrera B 356's they also had inverted discs like the maico setup... only today.. even more $$$ than a set of Maico's...
Keep the Thru Cal-Look Alive!!!!
