September 22, 2026, 21:24:32 pm
| |-+  For sale!
| | |-+  DTA S60 ECU Never used
Author Topic: DTA S60 ECU Never used  (Read 4093 times)
Andy Sykes
« on: January 05, 2014, 22:32:32 pm »
As above never used
over £800 bargain at £650
http://www.dtafast.co.uk/S_60_PRO.htm
reason for sale I cound not find anybody that has the experience or knowledge to tune my Pauter with DTA
« Last Edit: January 05, 2014, 23:30:26 pm by Andy Sykes » Logged
« Reply #1 on: January 06, 2014, 07:13:00 am »
Reason for sale I cound not find anybody that has the experience or knowledge to tune my Pauter with DTA
What? An ECU is an ECU no matter if it is a DTA, Motec, Autronic or anything else. Yes, the DTA is a bit more time consuming to map due to the lay out but it should be a no-brainer for anyone that can map an engine. Set the ignition, then the fuel, add the compensations and in the end add turbo pressure. Easy!
-BB-
Andy Sykes
« Reply #2 on: January 06, 2014, 19:30:13 pm »
Probably if you know how and confident in what you are doing. It's only changing an ecu about 2 hours work
Still here   Grin
stussyrich
« Reply #3 on: January 06, 2014, 20:43:46 pm »
Have you rang John Sleath Huh
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
Basti
« Reply #4 on: January 07, 2014, 13:53:57 pm »
For me the main thing is to setup all sensors and the loom.
This need to be done on every ECU.
As soon as this is working there is no difference to work on a pauter or standard block.
If you can find somebody who has a DTA S60 already running on aircooled it will start your engine as well!
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
