September 23, 2026, 00:22:20 am
| |-+  For sale!
| | |-+  BIG TIME SALE!!! UPDATED.... Bug/Bus/engine/wheels - Open to offers!!!
Author Topic: BIG TIME SALE!!! UPDATED.... Bug/Bus/engine/wheels - Open to offers!!!  (Read 3021 times)
« on: January 15, 2014, 16:11:05 pm »
Well here we go I thought it was about time I put ALL my items in ONE thread.....
Here is EVERYTHING I have for sale..... All items are located at the following address in NORWAY!
- Haakons Gate 9
- 1607 FREDRIKSTAD
- NORWAY
Just in case you want to collect......
Also I am driving over to the UK for VOLKSWORLD SHOW in a few weeks so I can deliver any of these items inc the larger/heavier stuff....
- x1 vintage/oldskool "Air-craft" oil cooler (see picture below!)
Approx 32"/800mm long & 3"/80mm wide - with x2 mounting tabs at each end,
Perfect for an old skool dune buggy or off-road rail
- £120.00 SHIPPED ANYWHERE!!!
- x2 Early 60's VW oil filler/breather WITHOUT the extra outlet! (only the drain tube!)
original vw items with original oil filler caps
- £10.00 EACH SHIPPED ANYWHERE!!!
- x1 "Industrial" 6v Dynamo stand - Original VW item,
This is the type with the 3 extra studs on the front - from an early 60's firepump engine,
- £12.00 SHIPPED ANYWHERE!!!
- x1 NoS/ VW-BOXED Headlight, For EARLY "Pre 61" Split Buses
This is an Original VW item WITH the large VW Logo on the glass and in its Original Box and even the ORIGINAL "Brown paper" from the factory!!This is a PERFECT NoS Part!!!!!!!!! Part No: 211941022A
-£350.00 SHIPPED ANYWHERE!!!
- x1 NoS/ VW-BOXED Headlight, For EARLY "Pre 61" Split Buses....
This is an Original VW item WITHOUT the VW Logo on the glass and in its Original Box and even the ORIGINAL "Brown paper" from the factory!!!! This is a PERFECT NoS Piece - Part No: 211941039
-£320.00 SHIPPED ANYWHERE!!!
x1 Early 60's Fuel Tank & Fuel gauge inc mechanical sender unit!!
This is an ORIGINAL 60's fuel tank I was saving but I am sure someone can put it to good use!
x1 fuel tank/sender & gauge
- £50.00 DELIVERED!!!
- x1 "doghouse" Oilcooler Mount
I removed this from a early 70's 1300cc motor
You can buy these repro (approx £40!!!) BUT this is an ORIGINAL VOLKSWAGEN item for under half the price!!!
Ideal if your building a bigger motor  Wink
- £18.00 SHIPPED ANYWHERE!
- x1 Early 50's (split) metal 6v battery cover,
I have had this laying around for ages and I am sure someone can use it for their restoration, This is an ORIGINAL VW item from a 1951 Split window "crotch cooler" car,
- £10.00 SHIPPED anywhere,
- x1 30hp VENTURI ring & themostat linkage,
I removed this from an old 30hp motor that had been sitting in our workshop for years,
This is 100% original VW item and perfect for a PROPER restoration
- £20.00 SHIPPED ANYWHERE!
- x1 PAIR of Early 60's Beetle Backing Plates,
these are in VERY good condition with all the adjuster tabs intact,
These are original VW items removed from an early 60's car,
- £30.00 SHIPPED ANYWHERE!
- x1 PAIR of early 60's linkpin spindles in very good condition!
all the threads are ok and there is even the little rubber gromet for the speedo cable,
- x1 Original 6v Dynamo pulley
This is an original 60's item in VERY good condition and ready to use
- £10.00 SHIPPED ANYWHERE!
- x1 PAIR of original vw Dual Port Manifold End Pieces  INC rubber boots & clips!
These are an original pair of LATE dual port end pieces from a late model 1600 engine,
They still have the original rubber boots and vw clips,
- x1 original Late Bay indicator lense HELLA/German!
an original hella indicator lense for the LEFT FRONT of a late bay window bus
- £8.00 SHIPPED ANYWHERE!
- 90% of a NOS front quarter panel.... for a PRE67 beetle......
Basiclly I brought a complete nos panel a few weeks ago and then CUT the piece I needed from it...... There are now 2 (two) fender bolts/threads missing from the rear most part.....I am sure someone can put the rest of this NOS panel to good use, Its PERFECT for making proper fitting repair patches.....
What you see is what you get.....
- £90.00 SHIPPED ANYWHERE!!!
- 1200/40hp Cylinder head tinware - mid 60's ...
I have for sale x1 pair (two) 1200/40hp Cylinder head tins from a mid 60's INDUSTRIAL firepump engine
These are original VOLKSWAGEN parts in very good condition, They will work with all the other tinware/exhaust parts I have for sale,
- 30hp Cylinder head tinware - Early 50's.......
I have for sale x1 pair (two) 30hp Cylinder head tins - from a early 50's 30hp oval engine,
These are ORIGINAL VOLKSWAGEN parts in very good condition for their age,
- Cool "industrial" Fan Housing - 1960's .....
 a COOL "Industrial" Fan Housing that I removed from a 60's Firepump engine I brought a while back, This is the early 1200cc style ie "non fresh air" and the oil cooler inside,
I was going to use it on my 65 but I decided I wanted better heating  Wink
As you can see it has ALL the original vw stickers and a COOL "Mesh" fan guard/cover which is all ORIGINAL FACTORY FITTED!!!
Being from a firepump means it has NO thermostat flaps etc,
- £40.00 SHIPPED ANYWHERE!!!
- X3 Bosch Logo'd Coil Clamps - Original VW items ....
I have for sale x3 BOSCH logo'd coil clamps - These are original VW FACTORY items form the mid 60's
These are a cool finishing touch to any old skool motor
- SW Ammeter gauge - 6volt - Rare! ....
This is a 6volt gauge, its ideal for an early bug..... I was going to use it in the 65 but I've changed my mind and I have WAAAAAAAAAY too many parts just sitting around gathering dust and I am sure someone can put it to good use....
£30.00 SHIPPED ANYWHERE!!!
- SW oil pressure gauge - 6volt type
This is a 6volt gauge but it does need a sender unit, its ideal for an early bug..... I was going to use it in the 65 but I've changed my mind and I have WAAAAAAAAAY too many parts just sitting around gathering dust and I am sure someone can put it to good use,
- X2 (pair) NOS/boxed Cal Custom Air Filters
These are original unopened 1970 custom parts - Perfect for that vintage parts display
As you can see they are in near perfect condition and I am only asking
- old "Home made" wooden dash panels
These actually came with the SW gauges I have for sale,
- £25.00 SHIPPED ANYWHERE!!!
- x1 ORIGINAL/NEW VW Michelin XZX 185 SR14 "Early Bay" Spare tire..... BRAND NEW (old!)
VW Michelin XZX 185 SR14 Spare tire for sale.....I have just removed this from the original spare wheel in my 68, This tire has never been used/driven and still has the little bobbles/tags on it..... This is ideal for a "Concours Restoration" as this is a PROPER VW fitment item,
- x1 early solid bug wheel... Wide 5/ 5x205...... Dated 2/64.... .....
x1 original vw "Solid" style early bug wheel, ideal if you are missing a spare wheel for your 1964 bug Wink
- £15.00
- x1 13/15/1600 SINGLE PORT manifold, From a late 60's 1500 motor,
Original condition & ready to use,
- £20.00 SHIPPED ANYWHERE!!
- x1 PAIR Buggy "lowback" fibreglass seats & covers, BRAND NEW!
These are the standrad seats sold by Rob @ East Coast Manx and come with x2 BRAND NEW covers in Blk "diamond sitch"  Smiley
- £150 each or £260 PAIR
- x2 BATTERY BOXES
Inc lid/cover, BRAND NEW!
- x1 PAIR (x2) Pre 67 Style FLARED Gasser front fenders/wings,
BRAND NEW!, NO headlamp bowls,
- £200.00
- x1 6v Dynamo backing plate,
Original VW item,
- £15.00 SHIPPED ANYWHERE!!!
Right I think thats it..... I do have various small interior parts/nuts/bolts/fittings etc etc so drop me a PM if there is something small you need..... I look forward to hearing from you all soon.....
Paypal: cookseylee89@yahoo.co.uk
Email: monki772003@yahoo.co.uk
Tel: +4740067168
Please check out my other ads for some cool/useful/interesting stuff
http://www.thesamba.com/vw/classifieds/search.php?username=monki77
« Last Edit: January 23, 2014, 01:23:26 am by monkiboy » Logged
« Reply #1 on: January 23, 2014, 01:23:57 am »
Updated and open to offers  Smiley
« Reply #2 on: January 28, 2014, 17:54:56 pm »
