November 02, 2026, 20:31:57 pm
Carb Set up Specs.
Topic: Carb Set up Specs. (Read 4449 times)
Warks_Dubber
Carb Set up Specs.
January 19, 2014, 01:08:24 am »
Evening all
Hoping someone could give me some advice on setting up my 48IDF's for my 2276cc engine?
I am running 82mm crank, 1.4 rockers, Wedgeport heads.. Hoping to set CR at about 10:1
From what I know the carbs are currently as sold in spec... which is:
◾40mm Venturi
◾150 Main jet
◾F2 Emulsion tube
◾180 Air corrector jet
◾0 Pump exhaust valve
◾55 Idle jet
◾50 Pump jet
◾2.00 Needle valve
Is this ok? does anything need to change?
Thanks as always.
Jas.
ED2.4
Re: Carb Set up Specs.
January 19, 2014, 16:24:13 pm »
Hi,
with 40mm vents ,i'd go with 165/170 main, 200 air
60 idle jets (maybe a bit fat,try 55 first )
F2 tubes are Ok ,50 pump jet and 200 needles too,
float level set at 10mm closed,
no more than 5 psi fuel pump pressure
DeluxeRacingTeam >>>>
http://charlie48ida.skynetblogs.be/
