November 02, 2026, 18:13:11 pm
Dry sump pump sections/stages
Topic: Dry sump pump sections/stages (Read 4267 times)
spoolin70
February 02, 2014, 13:38:24 pm »
Hi all - should be an easy answer for the right person
How are multi stage pumps such as pauter/autocraft/peterson connected internally ?
From pictures I see the pump bodies are made of sections but are the gears/shafts one piece or connected ?
In basic terms, can a 3 stage pump be made into a 4 stage by simply buying/adding another section ?
Darren
Ps, I'm looking for a 4 stage used pump if anyone has one. Depending on the answer, I would consider a 3 stage too
Stripped66
Re: Dry sump pump sections/stages
February 02, 2014, 23:14:04 pm »
The shafts are one-piece and the input shaft is keyed for the gears. If you had two 2-stage pumps, you could assemble the stages into a 3 or 4-stage pump if you had custom input and idler shafts made.
spoolin70
February 03, 2014, 08:22:32 am »
So it is possible to add stages but a bit more than just bolting parts together.
I did suspect it wouldn't be easy
Thanks Stripped66 for your answer
