October 12, 2026, 13:14:23 pm
Oval window sunroof measurements
Topic: Oval window sunroof measurements (Read 9292 times)
Frenchy Dehoux
February 12, 2014, 04:42:13 am »
I need someone that has an oval window 1956 or 1957 sunroof and give me the measurement from the edge of the center of the windshield rubber to the edge where the sunroof meets the opening. If you could have the measuring tape in the picture so I can see the distance. I really appreciate the help.
Frenchy
Doctor Detail ( Retired )
56BLITZ
Re: Oval window sunroof measurements
February 18, 2014, 00:06:17 am »
Hey Frenchy, I can measure mine for ya, but it has the windshield out of it. Is there some other measurement that would work?
Jesucristo es mi Seņor y Salvador!
Frenchy Dehoux
February 19, 2014, 03:25:56 am »
No problem that will be even better. From the inside edge of the windshield center to the edge of the sunroof.
Frenchy
56BLITZ
February 20, 2014, 23:36:55 pm »
Will do!
I'll take photos so you will be able to see exactly where I took the measurement.
It might be Saturday before I can post photos . . . hope that'll do for ya.
Frenchy Dehoux
February 22, 2014, 04:25:50 am »
I appreciate all your help.
Frenchy
56BLITZ
February 23, 2014, 02:13:03 am »
This is inside looking up to where the mirror mounts. I have the tape pressed to the header panel and running parallel to the reinforcement plate where the ragtop hook will catch.
It is 3 5/16" (3.3125") from the header to the 90 degree bend on the headliner clip.
Last Edit: February 23, 2014, 02:19:18 am by 56BLITZ
56BLITZ
February 23, 2014, 02:32:52 am »
This is for the outside . . . .
The dial-calipers are 12" and I have one jaw flat and tight to the opening where the ragtop hook will catch . . .
The other jaw is contacting the front edge of the windscreen opening.
The distance is "as the crow flies" . . . . 5.886"
Frenchy Dehoux
February 23, 2014, 19:15:36 pm »
Thank You very much for your help on this.
Frenchy
