October 13, 2026, 21:30:36 pm
| | |-+  Pauter pumps
Author Topic: Pauter pumps  (Read 6118 times)
Andy Sykes
« on: February 15, 2014, 19:38:22 pm »
Hi quick question I'm guessing the ports on the left are suction and the ones on the right are pressure
So that's three scavenge, one oil feed from dry sump, one return and oil pressure to engine. Andy would you feed the bypass from the filter to the sump or straight into the pump scavenge ?
Cheers Andy
russ fellows
« Reply #1 on: February 15, 2014, 20:49:40 pm »
Yes that's right. The first three stages are scavenge two from the sump one from the rocker cover of 4 end. The last is pressure. I return my bypass above the scavenge on the rocker cover
Andy Sykes
« Reply #2 on: February 15, 2014, 20:52:32 pm »
Ok thanks Russ Smiley
spoolin70
« Reply #3 on: February 16, 2014, 19:00:43 pm »
Hi Andy
Did you get your pump direct from Pauter or from another source ?
I've been looking for a used 4 stage for aaaaaages with no luck.
Darren
Andy Sykes
« Reply #4 on: February 16, 2014, 19:53:59 pm »
Hi yes direct from pauter with the motor
spoolin70
« Reply #5 on: February 16, 2014, 20:08:33 pm »
Cheers Andy
Good luck with the build, always look forward to an update on your build thread.
Darren
