September 22, 2026, 12:37:03 pm
Engine build advice
Topic: Engine build advice (Read 5226 times)
Rich_h
Engine build advice
February 16, 2014, 19:58:02 pm »
So I'm looking for some advice on my next motor build its a street & strip engine based around parts I've been collecting
so I have
74mm CB crank
Street Eliminator (42 x 37.5) 94 bore
94mm a spec pistons
Fk87
My questions is it best to run a set of
Cb Super Race Rods - VW rod journal - 5.325"
Or
Cb Super Race Rods - VW rod journal - 5.400"
With barrel spacers
On this spec
Cheers Rich
spanners
Re: Engine build advice
February 19, 2014, 17:26:48 pm »
With that short stroke you could use the short rods with good results, the higher piston speed/accelerations give good cylinder filling, but why only the 74 stroke? just Be sure to check piston underside clearance on the crank webs at BDC ,
Best regards, spanners.
February 19, 2014, 22:03:15 pm »
Definitely the short rods.
Taylor
February 20, 2014, 00:32:21 am »
Yeah because you're going to notice the .075". Use whichever ones you can get cheaper. unless you're hell bent on making your motor .150" narrower.
Rich_h
February 21, 2014, 00:34:46 am »
I have been collected bit over the last few years and in so my build has change over & over again
The first plan was to be 74mm & 92mm 1967cc but the 94mm cut heads turned up so all Change
Plus want to build something different
