October 28, 2026, 16:37:38 pm
Hanibal1
My new 56 project
6
Topic: My new 56 project (Read 286134 times)
kev d
Re: My new 56 project
Reply #30 on:
October 02, 2016, 23:35:22 pm »
Moving slowly is always better than not moving though Larry!
Kev
Frenchy Dehoux
Reply #31 on:
December 25, 2016, 05:31:33 am »
Nice project Larry i am following it.
Frenchy
Doctor Detail ( Retired )
Larry S
Reply #32 on:
February 22, 2017, 02:00:05 am »
Thanks Frenchy, I have been collecting some parts. I hope to get the body back in a couple of weeks and start on the bodywork. I have some pretty cool parts going on the car, hopefully it will be nice.
Larry
Larry S
Reply #33 on:
February 25, 2017, 15:01:16 pm »
Some parts I have been collecting for the car. An old breather like I use to run on the black car, it will clean up nice. A Berg traction bar never been used, I ran one of those on the black car as well. and a Treuhaft deep sump, great condition, given to me by a great friend as a donation to the project.
Larry S
Reply #34 on:
February 25, 2017, 15:02:34 pm »
the deep sump
Larry S
Reply #35 on:
April 23, 2017, 15:36:02 pm »
Received my new panels from Steve at Hookeys Panels in the UK, top notch guy with top quality parts! Thanks Steve.
Larry
Larry S
Reply #36 on:
April 23, 2017, 15:38:53 pm »
I got a set of rebuilt hinges and installed the passenger door, still needs some alignment work but close, door could not even open when I got the car.
Larry S
Reply #37 on:
April 23, 2017, 15:43:36 pm »
panels that will be replaced
Larry S
Reply #38 on:
April 23, 2017, 15:44:55 pm »
like Christmas in April!
Larry S
Reply #39 on:
May 23, 2017, 18:33:09 pm »
I took the body over to the metal guy this weekend. he is replacing the rust areas and some dented areas. he does great work so I am excited to get this phase going. final bodywork and paint next.
Larry S
Reply #40 on:
July 12, 2017, 14:20:36 pm »
I received the birth certificate from VW, the car was originally prairie beige with red leatherette interior....still pondering the color.
Frenchy Dehoux
Reply #41 on:
July 13, 2017, 03:18:06 am »
Larry your project is looking great if you are looking for some particular parts let me know . Are you going to install a 36 hp back in it or going with a bigger motor with the IDA'S.
Frenchy
Larry S
Reply #42 on:
July 13, 2017, 14:40:13 pm »
Thanks Frenchy,
I am going with a updated motor with IDA's. I originally was going 36hp with Okrasa kit but IDA's are just so awesome I can't help myself. I ran them for years on the street and nothing like them. I probably won't go to big, 1776 maybe, I want a weekend driver that I can enjoy. My old motor was a 1750 (69x90 npr's), 40x35.5 ported heads, Engle VZ73 cam, it was great. I am basically starting from scratch on the motor, would like to buy one done but so hard to trust anyone these days, I might have to buy the parts and build it myself, and that's ok too.
I was going strato silver but leaning towards the Prairie Beige with red interior (original to the car), if the paint job is really nice I think it could look great. Beige has to be done really nice to pull it off.....
Thanks for the encouragement, I have always enjoyed your cars and look at them as a goal for mine to turn out!
kev d
Reply #43 on:
July 13, 2017, 23:32:52 pm »
Looking good larry
The hookey panels are good aren't they!
Kev
Larry S
Reply #44 on:
July 19, 2017, 19:08:48 pm »
Metal work coming along, both doors mounted using rebuilt hinges. bottom hinge on drivers door was ripped away from door, rivets all torn through, it is all fixed.
yes Kev the panels are great!
Last Edit: July 19, 2017, 19:12:15 pm by Larry S
Larry S
Reply #45 on:
July 19, 2017, 19:09:42 pm »
more
Larry S
Reply #46 on:
July 19, 2017, 19:10:32 pm »
more
Reply #47 on:
July 19, 2017, 21:53:18 pm »
Quote from: Larry S on July 19, 2017, 19:08:48 pm
Larry, I'm sure I've posted this somewhere before, but I was once told to load the doors up with glass, wonders and seals when setting door gaps as it gives the correct weight and sag on the hinges. Did it on a car I was working on and the gaps came out perfect.
Larry S
Reply #48 on:
July 20, 2017, 13:16:53 pm »
Thank you Neil, good information!
Larry
Larry S
Reply #49 on:
August 02, 2017, 02:45:52 am »
I found a 22 year old berg 1 5/8" merge header and dual muffs that was never used. I use to run these back in the early 80's and like the look so I wanted to get the setup for my 56.
Jeff68
Reply #50 on:
August 02, 2017, 14:36:42 pm »
Nice Header and dual QP set! Best looking / fitting there is!
Larry S
Reply #51 on:
August 02, 2017, 16:56:29 pm »
I agree, that's why I wanted this setup. I ran a wanted to buy add on the Samba for a year and had 2 people contact me, the first wanted way to much for it but this one was reasonable. I will get the muffs cleaned, sanded, and painted with header paint. I always liked how the Berg units tucked up compared to the others.
Larry
Larry S
Reply #52 on:
August 07, 2017, 22:42:14 pm »
Mufflers all cleaned and painted.
Larry S
Reply #53 on:
August 07, 2017, 22:44:38 pm »
one more
Reply #54 on:
August 08, 2017, 00:43:15 am »
Sexy
Larry S
Reply #55 on:
November 21, 2017, 19:32:51 pm »
Metal work coming along, slow...but moving forward.
Larry S
Reply #56 on:
February 08, 2018, 22:20:57 pm »
passenger bumper mount on, now the engine bay metal and apron, have to make sure everything aligns perfectly, nothing worse than fenders and apron not aligning perfectly....pet peeve of mine.
Larry
Larry S
Reply #57 on:
February 08, 2018, 22:24:25 pm »
I was given a 1975 bug motor for free so I have torn it down and the case looks nice so it should be a good base for my motor. I will be sending it out for machine work soon.
Reply #58 on:
February 09, 2018, 07:44:24 am »
Coming along nicely Larry. I was once told that late 1200cc motors are great as case donors, as they have the best factory oiling but the heads are so restrictive they can't be over-revved to knock the saddles out!
karl h
Reply #59 on:
February 09, 2018, 08:04:42 am »
very nice project! have you decided on the colour yet?
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
6
