October 13, 2026, 07:18:07 am
AN style fittings.
Topic: AN style fittings. (Read 8898 times)
steve_pugh
AN style fittings.
March 21, 2014, 13:47:01 pm »
Hi.
What is the thread size / type of the thread that I need for the various full flow items for my case, oil pump cover, filter head etc etc?
Can I buy the AN swivel type connectors that fit directly to my items or do I need a thread converter to allow this?
Same for using the AN style fittings for the carbs etc.
Lastly, what size AN fittings do I need for 1/2" Oil hose? AN10?
And what size would it be for 8mm fuel hose?
This is new territory for me. And there doesn't seem to be a huge amount of help even if I google, (probably because I need a little bit of knowledge to start with... :lol: )
Thanks all.
VW Beetle '72 Herbie. 2276 FK10 48IDA
PB: 13.46 @ 98.04mph
www.facebook.com/rabbitracinguk
http://www.vwdrc.com
http://raceshifter.de/index.php?language=en
Re: AN style fittings.
March 21, 2014, 14:04:33 pm »
Basic info that might help.
http://en.wikipedia.org/wiki/AN_thread
http://anfittingguide.com/
https://www.google.com.au/search?q=AN+fittings&client=firefox-a&hs=Uwf&rls=org.mozilla:en-GB:official&channel=sb&tbm=isch&tbo=u&source=univ&sa=X&ei=7jUsU9CeMM3gkgXp9oGwBg&ved=0CEwQsAQ&biw=1600&bih=770
Honestly, I just love Google! The biggest damn library in the whole world (and very difficult to burn down!).
My local library is still dragging itself kicking and screaming into the 1970s..........
spoolin70
March 21, 2014, 14:48:53 pm »
If you need any more info :
http://www.jgbhose.com/base_pages/coupling_identification.asp
Jonny Grigg
March 21, 2014, 20:55:20 pm »
Try Speedflow or mocal for fittings.
Not sure which parts you have, but the thread is usually 3/8NPT in the pump covers, filter heads etc. if you are going to for the Aeroquip style of fittings, use -8 for the oil system (I.e. You fit a 3/8NPT to -8 male/male fitting in the pump cover, filter head etc, then use the -8 swivel fittings on the hose. You need to get the hose to match the fittings but the speedflow website is quite comprehensive- I think this is 1/2" hose but have a look on the website.
No idea what carbs you are using, but if they are ida style, then I suggest you get the Jaycee type fitting to remove the banjo, then use -6.
Be warned- this lot comes out expensive........ When I plumbed my motor and fuel system I spend way in excess of £1000 in hoed and fittings.
No Compromise. O/FF111
March 21, 2014, 21:22:17 pm »
AJ (Low Buget) has an brand of AN fittings that are a very nice quality and good prices
http://selvedgeyard.com/
vaughn bros
March 21, 2014, 21:46:44 pm »
Earls has a 3/8NPT Swivel Male with a #8 Hose end. Works great for me. Clears the pulley and only slight mod required for Tin. Street car mind you.
dannyboy
March 22, 2014, 19:32:58 pm »
tourques uk on ebay is a good very good price id say around half the price of earls in uk
8.77@156.8mph
O/FF 60
Kiel
March 22, 2014, 20:37:35 pm »
http://appfittings.dk/velkommen
andy198712
March 22, 2014, 23:32:03 pm »
may i ask why you want all AN style fittings?
i'm planning a dry sump so interested too over say, pushloc's or even barb and clamp...
interesting thing....AN stands for Army Navy, and the helicopters at i work on (navy) are dripping in the stuff.
steve_pugh
April 07, 2014, 14:54:21 pm »
Quote from: andy198712 on March 22, 2014, 23:32:03 pm
Partly for looks... but mainly for practicality. Can remove a hose / fitting without ruining the hose. Plus I'm sick of Jubilee clips breaking, coming loose etc. It just looks professional, probably because it is more professional and safe than push on barb fittings and Jubilees..
I learned the other day that AN and JIC are one and the same standard. So that opens up options as to locations I can buy stuff. :-)
andy198712
April 08, 2014, 16:30:29 pm »
What's JIC used for? ie where to look to buy if its cheaper?
Yeah good points to choose AN!
Andy Sykes
April 08, 2014, 19:00:45 pm »
Jic is used a lot on hydraulics jic will also have a small ID but the thread sizes and cone are the same as -AN
Last Edit: April 08, 2014, 19:45:28 pm by Andy Sykes
