October 14, 2026, 06:59:16 am
| | |-+  Centrelines - What bolts/nuts and where?
Author Topic: Centrelines - What bolts/nuts and where?  (Read 7884 times)
ballbag
« on: August 10, 2007, 20:31:27 pm »
I am buying these wheels off Rob (54caldub)
My question is, does anyone know which bolts or nuts i need to fit them to my bug???
Also, where do i get them???
something funny!
63 ripper
« Reply #1 on: August 10, 2007, 22:41:56 pm »
you should use 14mm studs,press ins are best. then a ball seat nut. try machine 7 or here
http://www.mistertee.co.uk/index.html
you might need tubes depending how the "strip" that seals between the two halfs is.
be aware those fronts will not fit discs unless you use a BIG spacer to push the wheel away from the caliper. also if you have drums,normal spindles and a narrow beam they are going to look silly,too narow. they look good on a stock width beam with drums etc
those rears look deep dish,there are a few different offsets in 6 inch centerlines....bug buggy etc
« Last Edit: August 10, 2007, 22:43:31 pm by 63 ripper » Logged
JG54
Rune
SCC Crew
Screwdrivers #7
« Reply #2 on: August 11, 2007, 20:01:08 pm »
The stock lugnuts will work just fine aswell...
