September 23, 2026, 18:05:47 pm
| | |-+  Fuchs paint code.
Author Topic: Fuchs paint code.  (Read 5785 times)
« on: March 23, 2014, 09:57:27 am »
Hi all,
I would like to find a paint code that match the OEM finish to repaint a set of late fuchs. I found on Pelican parts forums that Rustoleum did a paint that looks close, but I can't find it over here.
I try an epoxy RAL 9006 grey paint, but I'm not even close.
It doesn't look bad either...
Do anybody can point me in the right direction?
Thanks.
henk
« Reply #1 on: March 23, 2014, 11:00:06 am »
I thought they where anodisd new,not painted.
That was what gave them that original color.
Maybe worth to gave a look at that,it is not that expensive.
Henk!!!
« Last Edit: March 23, 2014, 11:01:42 am by henk » Logged
« Reply #2 on: March 23, 2014, 12:49:40 pm »
Henk!!!
Yes, they originally are anodized but I don't know where to get them anodized. So it's easier to paint them myself.
hotrodsurplus
« Reply #3 on: April 14, 2014, 10:17:27 am »
I know where to get them anodized for really cheap: your garage. Here is how:
http://www.benneynlinda.com/files/banquet/hobbies/files/how-to/diy_home_anodizing.html
Cut down a plastic trash can to make the anodizing 'tank'. The acid will not affect the plastic.
Because you don't want to color the aluminum you can skip the dye. If you do dye other parts remember that red fades very quickly when exposed to the sun.
After anodizing you have to boil the part to seal the surface. Get a metal pail big enough to fit the wheel and a burner like this.
http://www.webstaurantstore.com/backyard-pro-square-single-burner-outdoor-patio-stove-range-sq14/554BPSQ16.html?utm_source=Google&utm_medium=cpc&utm_campaign=GoogleShopping&gclid=CMWz-v7P370CFROVfgodJyIARg
You will get the best finish if you completely polish the part before you anodize it. The duration in the anodizing 'tank' determines the reflectivity and the durability. A short dunk will preserve most of the shine but the finish will be delicate. A long dunk will produce a dull, tough finish that will last forever.
Please don't paint your wheels silver. It is easy to anodize.
« Reply #4 on: April 14, 2014, 11:10:38 am »
Cool!
Thanks for the tip!
« Reply #5 on: April 14, 2014, 13:32:47 pm »
Thanks for the tip!  Wink
