October 12, 2026, 10:04:27 am
| | |-+  Irs axle lenght question ??
Author Topic: Irs axle lenght question ??  (Read 6341 times)
mr horsepower
« on: April 03, 2014, 16:31:24 pm »
Hello as my diff in the autobox sits of centre i need to make two different length of axles .
Now i want to know how can i determite the proper length of the axles
Flange to flange is 36 and 43 cm but does it protrude or keep it back
can someone measure it on a stock irs bug ?
So i will have the dimentions
what i try to do is take 4 golf 5 gti long side axles  i only need the the trans side these splines are the same as the 944 cv joints
the  are 42 mm in dia hollow tube .
Cut them to lenght  make a insert on the lathe so the will slip fit and then have them welded.
Any advise is welcome
gr henri
« Last Edit: April 03, 2014, 17:57:42 pm by mr horsepower » Logged
« Reply #1 on: April 04, 2014, 02:43:57 am »
What I have done on the Fiat and now on the Ghia is get the axle stub and the trans hub level -- this will be the shortest distance needed -- then measure from the bottom of each -- take this distance minus 5mm and that is the axle length I order
mr horsepower
« Reply #2 on: April 07, 2014, 19:56:41 pm »
Did it that way and it fits.
 Thanks fiatdude
Gr henri
