August 12, 2026, 20:47:21 pm
stock or 2inch beam for deep 6 fuchs
Topic: stock or 2inch beam for deep 6 fuchs (Read 6260 times)
dannyboy
April 21, 2014, 20:00:55 pm »
there is a 4 inch beam on my car at the mo with deep 6 fuchs and the steering lock is shocking .can i get away with a stock width beam or do i need a 2 inch one?
hope that makes sense
8.77@156.8mph
O/FF 60
Re: stock or 2inch beam for deep 6 fuchs
April 21, 2014, 20:36:15 pm »
2" works fine, with drop spindles.
April 21, 2014, 21:57:44 pm »
It depends on how wide tires you are going to use on them. I have fitted 6" fuchs to the front of four vw's and have never owned a narrowed beam.
dannyboy
April 21, 2014, 23:11:47 pm »
145/80/15s and drop spindles with stock discs drilled for 130pcd
8.77@156.8mph
O/FF 60
April 22, 2014, 07:48:54 am »
Quote from: Zach Gomulka on April 21, 2014, 20:36:15 pm
I used 185/60, same height as a 145 but wider. Fit was perfect.
145 will be quite stretched on a 6" rim.
April 22, 2014, 10:58:32 am »
I have used 145/80/15" on stock linkpin beams with a 17mm thick adapter. On 6" fuchs 36ET. I love the way it looks.
April 22, 2014, 15:00:12 pm »
Quote from: Jon on April 22, 2014, 10:58:32 am
To each his own. I prefer the tire to at least be slightly wider than the rim for protection and looks.
Doktor
April 22, 2014, 18:33:32 pm »
Not to mention handling and braking...
dr.aircooled
April 22, 2014, 20:47:56 pm »
Quote from: Doktor on April 22, 2014, 18:33:32 pm
Goes without saying
Mike Lawless
April 23, 2014, 16:49:46 pm »
I think a lot of it depends on the drop spindles you use and how much they move the wheel outward. Many of them move the wheel out as much as 3/4" (19mm) per side. In this case, the 2" narrowed beam would move the wheels back close to stock position.
The Fuchs have a pretty good offset to the inside. Even so, maybe with a beetle, you can get away with a stock beam. My experience has been with a Ghia, and with that you need the 2" beam so the tires don't hit the fender arch.
I've run a 135 and a 145 on 6" wheels. No es bueno! There are some nice low profile tires with a wider tread that would work pretty good. Made for Smart cars.
I ended up sending the wheels out to be narrowed.
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
April 23, 2014, 16:57:28 pm »
I've got 16"x6" teladials on a stock beam and needed a 13mm spacer to get them 'right' on my ghia
http://selvedgeyard.com/
