November 02, 2026, 18:45:27 pm
| | |-+  Camber compensator
Author Topic: Camber compensator  (Read 6302 times)
pamo
« on: May 03, 2014, 23:52:47 pm »
Hey guys, just wondering the advantages/disadvantages (if any) of running a camber compensator?
I will be running a late 1500 swing axel box with a 150hp 2110 engine in a 63 bug. I am also panning to run MH racemasters. Any advice would be greatly appreciated.
« Reply #1 on: May 04, 2014, 02:15:50 am »
The only disadvantage is, it takes longer to pull trans and you cant run a gusseted trans case with one without some creative engineering.
pamo
« Reply #2 on: May 04, 2014, 07:34:56 am »
Thanks john, so it should be fine with a standard box?
« Reply #3 on: May 04, 2014, 15:20:38 pm »
Yes. Definitely an improvement.
« Reply #4 on: May 04, 2014, 16:03:19 pm »
I've had one on my '66 for years.  It definitely calms down the rear end in high speed sweeping turns.  If you don't drive your car you don't need it.   If you drive your car hard then you'll be glad you have it.
« Reply #5 on: May 04, 2014, 17:48:21 pm »
I fitted one with a HD anti roll bar at the same time, great improvement!!
« Reply #6 on: May 06, 2014, 20:04:18 pm »
if you're running drag tires, then how concerned are you with going around corners?
pamo
« Reply #7 on: May 13, 2014, 23:45:41 pm »
If I can improve the handling of a swing axel car I think I should. It will still be a street car, the tyres are probably more for looks than anything else. Thanks for all your help guys.
Sepi
« Reply #8 on: May 15, 2014, 05:46:05 am »
I got some problems to fit the original bracket to Rancho pro-street gearbox, so I did this kind of bracket.
