September 22, 2026, 22:17:52 pm
| |-+  For sale!
| | |-+  55 oval 2,7 engine, rollcage,porsche brakes,wishbone +++++
Author Topic: 55 oval 2,7 engine, rollcage,porsche brakes,wishbone +++++  (Read 3146 times)
ASSY
55 and 59
« on: May 04, 2014, 06:57:36 am »
The black Oval is going for sale , that i have lost the interest.
The price is 200 000 norwegian krones or approx, 25 000 Euros
The engine is fresh from get back on track from Denmark.
The engine is not in the car, dry sump have to be mounted, the only thing you have to buy is the oil lines for it.
THE CAR IS IN NORWAY
I have reciets for everything and the built cost is very high.
here is some facts.
everything new or restored.
Pan off restoration
T4 engine 2,7 autronic fuel injected.
915 tranny new built with LSD
930 C`v and stub axles, 300M axles
Eyeball engineering front suspension coil over. Eyeballengineering.com
MBT engineering coil over rear suspension. mbtengineering.com
Porsche Big red brakes, 993 turbo front, 965 turbo rear
944 Turbo steel trailer arms
17" original Fuchs 7,5" front 8" rear
Steel braided hoses all around
944 master brake pump with reduction valve from MBT engineering
I did tilt steering column
Grant steering wheel
Vdo instruments
Autometer monster tach with recall and shift lite
semaphores 12 volt
Aluminium gas tank
steel roll cage
Floor pan stiffeners from Usa
Seats from Sebring 5900 leatherette / corduroy
Modified rear apron to take off
Modified deck lid, the engine is big and therefore the scoops
Engine new built  from get back on track
2,7 T4 engine with all the the right parts
Dry sump system Torstein pieper
Fragola fuel lines all the way
oil cooler with fan and thermostat
Steel wings widener, 20 mm front 32 mm rear
Steel fenders
Tinted green windows
To Many things to list.
Contact me for more info if interested.
Here is a web link for pictures:   http://www.finn.no/finn/car/used/object?finnkode=48168162&searchclickthrough=true
Asbjørn e post :olaf-as@online.no
mobil:41682000
« Last Edit: May 04, 2014, 07:00:12 am by ASSY » Logged
Assy
svein
« Reply #1 on: May 15, 2014, 21:59:32 pm »
Beautiful car.
Good luck with the sale Asbjørn :-)
Best regards Svein.
Vw 1960 Rag. 2332ccm Engine.
201 m = 8,063@136,42km/t.  402m = 12,808@165,77 km
