July 23, 2026, 18:03:08 pm
| | |-+  '67 seats frame question?
Author Topic: '67 seats frame question?  (Read 9553 times)
Brian Rogers
« on: May 13, 2014, 20:10:30 pm »
Are there any differences in the seat frames for convertible compared to a sedan? I have the HotVWs tech book. Anything else to watch out for?
Thanks again for your help.  Grin
« Reply #1 on: May 13, 2014, 20:46:20 pm »
There are two styles, late 66- early 67 with the back release on the bottom, and the late 67 with the release on the side of the backrest. Vert and sedan are the same.
deano
« Reply #2 on: May 13, 2014, 21:30:49 pm »
There are differences for true convertible seats, but nothing frame-related. There are eyelets sewn into the base of the upper cushion to allow moisture to drain out. You can't see them, unless you move the top cushion full-forward, and look underneath. My '67 vert still had original seat covers, and Lenny Copp showed them to me... Another '67 trivia question.
Anglia Obsolete Guru
'67 Heaven
Brian Rogers
« Reply #3 on: May 13, 2014, 23:04:32 pm »
Nice, good info. Thank you.
Critter1
« Reply #4 on: May 15, 2014, 14:43:05 pm »
That is some interesting info... Soon as you think you've heard all the 67 trivia ---there's more!  Ugh, 67's!! It's a love hate thing.
Brian Rogers
« Reply #5 on: May 15, 2014, 14:59:05 pm »
Where else are you going find this stuff out. Deano before Ahlshiemers claimes your brain another leagacy you could leave is a tome of '67 trivia. I know of other pages dedicated to it but you seem to know it all. Thank you for your help.
deano
« Reply #6 on: May 15, 2014, 18:19:11 pm »
Okay, here's today '67 Trivia.... Front Hella turn signal lenses... These were used from '63-'67. But, '67s should have the number "66" on them, instead of the normal "63". Now back to our movie...
'67 Heaven
neil68
« Reply #7 on: May 15, 2014, 19:02:56 pm »
One thing to keep in mind, is that "low-backrest" front seats continued into the '68 Beetles in many countries, and on into the mid-70's. models. So, check the classifieds for some of these export models and parts.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
deano
« Reply #8 on: May 15, 2014, 20:51:38 pm »
If VW continued to use a low back seat past 1967 in certain markets, I wonder if the design stayed the same as late '67?
'67 Heaven
neil68
« Reply #9 on: May 16, 2014, 02:28:20 am »
IIRC, only the backrest stayed the same as the '67 style-i.e. low.
The seat bottoms were upgraded similarly in most/all markets.  For example, the 73-up seat (bottom) mounts used the third "middle" track system, the same as in North America...but combined with the late-67 low backrest and high release lever.
Neil
« Reply #10 on: May 16, 2014, 12:15:56 pm »
I believe the tracks are wider starting in 71-ish, tri-pods began 73.
