September 23, 2026, 00:17:48 am
MeXXspeed NBAC Billet crank
Topic: MeXXspeed NBAC Billet crank (Read 15165 times)
MeXX
May 16, 2014, 21:21:16 pm »
Hi
After I broke my crank last year I had to realize that I'm in the need of a stronger solution.
Now 8 month later I'm more then proud to release my new designed NBAC billet crank.
just for comparison NBAC vs of the shelf Scat billet crank.
Keep on cranking
MeXX
Drag or Die
johandryselius
Re: MeXXspeed NBAC Billet crank
May 16, 2014, 21:31:55 pm »
Mexx!
VERY nice as also your billet heads! Any new times set yet!?
Johan
1600cc Challenge Porsche 356:
9,4386@242,48km/h; 6,1229@193,15 km/h 1,50 60 foot @ Kjula Dragway 2022
1600cc Challenge Buggy:
9,5112@225,42 km/h; 6,0624@185,85 km/h 1,38 60 foot @ Kjula Dragway 2020
Europes quickest ProStock VW:
9,8538@218,80 km/h; 6,2569@176,24 km/h 1,35 60 foot @ BRC Tierp Arena 2014
MeXX
May 16, 2014, 21:48:48 pm »
Stepping up to larger 65mm main bearing the overlap between main and rod journal was increased from 7.9mm to 10.4.Which is basically even more than a 84mm stroke crank
The main journal radius was increased to 3.2mm. The webs between main journal #3 and rod journal #1 & #4 were increased in thickness from 8.83mm to 9.87mm and in width from 78.15mm to 104.83mm resulting in a square area increase of 50%.
Last Edit: February 21, 2021, 18:40:01 pm by MeXX
Drag or Die
MeXX
May 16, 2014, 21:58:27 pm »
Even the thick webs were increase slightly to gain rigidness.
The oil bores for the rods were reduced to reinforce the webs and to gain bearing surface.
MeXX
Drag or Die
MeXX
May 16, 2014, 22:03:28 pm »
I'm very proud to have two of this beauties for my new engines and that the first crank for a customer is in production right now and will be delivered soon.
So long
MeXX
Drag or Die
bedjo78
May 17, 2014, 00:42:31 am »
That is amazing
dangerous
May 17, 2014, 03:58:43 am »
Nice design work Mexx!
Love the curves and extra material right where it needs to be!
I went for 4mm radii and 2.75"(about 70mm) mains on mine.
2.2" (about 56mm)rod journals and only 82.5" stroke.
I did mine old school, on non-cnc and it took 90hours!
wph
May 17, 2014, 07:50:11 am »
Slightly off topic but:
Mexx and dangerous, how did you model counterweights and balancing ? My cousin has a back burner project for his
inline Ford engine for which he'd like to machine a stroker billlet crank.
Pekka
jaqo
Bugster Team
May 17, 2014, 11:32:37 am »
Great work Mexx, as allways
Quote from: dangerous on May 17, 2014, 03:58:43 am
Wow:D:D
May 17, 2014, 13:07:01 pm »
Quote from: MeXX on May 16, 2014, 21:21:16 pm
Hi
Keep on cranking
MeXX
Hi Mexx
very nice
, are you making them yourself or having them made to your specs? with a 60mm main bearing will they fit into a type 1 case or does it need to be something like Pauter? what bearings will it use? what do you use for the thrust?
MeXX
May 18, 2014, 07:00:12 am »
Quote from: richie on May 17, 2014, 13:07:01 pm
Hi Mexx
very nice
Dear Richie
They are made to my spec.
65mm bearings are of the shelf.
The fit T1 with a new line bore slightly smaller than T4.
The of the shelf bearings come with a thrust bearing similar to T1.
will ad a pic soon....
sorry but just got up and it was such a long (great) day yesterdays.
WRH
MeXX
Last Edit: February 21, 2021, 18:41:15 pm by MeXX
Drag or Die
May 18, 2014, 08:41:00 am »
Quote from: MeXX on May 18, 2014, 07:00:12 am
Hi Mexx
very nice
Dear Richie
60mm bearings are of the shelf.
WRO
MeXX
Hi Mexx
thankyou, now take a break for 1 hour, enjoy what you achieved yesterday
then go work on the car to make it better
Ragtop
8.93 at SCC 2012
May 18, 2014, 21:33:41 pm »
You are a very talented man!
MeXX
May 22, 2014, 18:36:51 pm »
Hi
Here are some pix from my bearings.
They are available of the shelf in different materials for different levels of performance
MeXX
Drag or Die
mr horsepower
May 22, 2014, 19:22:48 pm »
They look like ford small block to me Mex
Maybe i am wrong but for me they look like it
Btw congrats with youre achievement on the run
You are writing history
Gr henri
Shag55
Shag Leone, SL-1racing
June 19, 2014, 21:36:39 pm »
Another very nice product Mexx!
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
Type3s
June 20, 2014, 10:25:06 am »
Hi MeXX,
now the good piece lying on my table, awesome!!!!
Thanks for everything, looking forward to the future ....
some pics
Daniel
Last Edit: June 20, 2014, 10:29:07 am by Type3s
UltraOrange67-2443
August 15, 2014, 16:16:06 pm »
Quote from: MeXX on May 22, 2014, 18:36:51 pm
Hi
MeXX
Hi Mexx,
Can you supply a rear thrust bearing in a T4 outer / inner dia?
1967 1200 2920cc EFI
