October 12, 2026, 07:00:43 am
| | |-+  Project 64
Author Topic: Project 64  (Read 6944 times)
Beastofabug
« on: May 17, 2014, 13:28:36 pm »
hi guys new to the site so thought id post some info and pics of my project current spec
1641cc
110 cam
single twin 40
1500 box
new spec nearly done
44mm Webbers IDF’s
CB044 Wedge port heads 44mm inlet, 37.5 exhaust
Engle FK10 cam
1700lb KEP clutch cover
200mm steel forged lightened flywheel
External Oil filter
external cooler and fan
Full flow AS41 Engine case
Filter king pressure regulator
pertronix 2 system
CB hex bar
75 Amp Alternator
CSP Oil Pump Cover, Billet Aluminium, 1200-1600cc, 3/8npt for Full Flow, with Pressure relief
Deep Sump kit
SCAT 84mm Stroke Counterweighted Crank
5.500" chevy journal forged con rod set with arp 2000 bolts
Chevy Rod Bearings
Mahle 94mm Stroker kit
Manton cut to length chromoly pushrods
Genuine Cush lock disc
KEP Stage 2
steel straight cut cam gear set
SCAT Pro Comp 1.4:1 ratio rocker arms
CSP Python 45mm Exhaust
Gearbox being built by John Walklett
sway away race shafts
wide 5 disc's all round
linelock
Just waiting till i've got all the parts together then I start
