June 10, 2026, 12:33:02 pm
352171 Posts in 28909 Topics by 6919 Members
Latest Member: mvptkfjb
| | |-+  Once you go black...
Author Topic: Once you go black...  (Read 22000 times)
glenn
« on: May 19, 2014, 23:07:03 pm »
I'll explain.
The weld between the two mufflers on my dual QP mufflers has cracked so I'm getting it repaired. They have to grind off the ceramic coating to do it so I have to get it recoated. As it turns out I have another muffler system that has a small dent, I put it on so I can drive the car. It's bare metal but looks almost black. Since i'm getting the old one recoated, I can change it from high luster silver to black.
So should I??
« Last Edit: May 19, 2014, 23:09:15 pm by glenn » Logged
Glenn
www.DasVolks.com
Long Island's Aircooled Club
ESH
« Reply #1 on: May 19, 2014, 23:15:09 pm »
We had a silver coated one on a late car with bumpers and changed it to black, the black is much better, (I think).
Cheesepanzer
« Reply #2 on: May 20, 2014, 00:43:45 am »
IMO, black looks best with the old school style QP's.  If you like the protection of ceramic coating have the QP's ceramic coated in black.  Trouble is, I don't believe you can leave the tips chrome then, which to be "correct" needs to happen.
I've always dug the looks of the early merged QP's when they tuck up inside the fenders a bit and make the tips level or slightly pointed down.  Looks tuff.   Cool
63 Type 2 Single Cab
Cornpanzers
glenn
« Reply #3 on: May 20, 2014, 01:57:49 am »
Like this?
Glenn
www.DasVolks.com
Critter1
« Reply #4 on: May 20, 2014, 01:59:11 am »
Black for sure.. The coaters can tape off the chrome tips, but I'm sure you know that Glenn.
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #5 on: May 20, 2014, 03:53:41 am »
I think the black looks better on the duals Glenn.
« Reply #6 on: May 20, 2014, 06:24:18 am »
The silver mufflers say "Hey look at me, I don't have a stock engine". The black mufflers are less noticeable.
« Reply #7 on: May 20, 2014, 07:15:26 am »
Out of the two choices I would go for satin black but that said I have really never liked the look of an exhaust that stick out like the dual muffler/fat boys etc. Is it a history/vintage thing? It surely cant be a performance thing since you today can get a really nice performance exhaust that is tucked nicely under the apron and exit where it should. I think the rear of your car would look better without the exhaust hanging out.
Just my two cents.
Best rgs
BB
henk
« Reply #8 on: May 20, 2014, 07:32:56 am »
Like the most here,i would go for black as well.
Henk!!!
volksnut
« Reply #9 on: May 20, 2014, 15:24:38 pm »
Black
« Reply #10 on: May 21, 2014, 01:04:43 am »
You don't have to grind off the coating -- most coaters will burn it off before recoating
glenn
« Reply #11 on: May 21, 2014, 01:38:49 am »
Grind it off to fix the weld.
Glenn
www.DasVolks.com
Taylor
« Reply #12 on: May 21, 2014, 03:27:01 am »
Just my two cents.
Best rgs
BB
Did you forget what the name of this forum is?
Jason Foster
« Reply #13 on: May 21, 2014, 05:14:41 am »
   ^^^like.
« Reply #14 on: May 21, 2014, 05:52:50 am »
Nope, but that no excuse for poor looks.
-BB-
dive!dive!
« Reply #15 on: May 22, 2014, 08:17:55 am »
-BB-
I do agree - from a personal perspective. I've always wondered why folk don't fill in the original cutouts if they are not being used ? And, as you say there are some killer exhausts out there these days that are very discreet.
However, part of the fun of our 'hobby' is that there are so many flavours of what can be done, so each to their own I say.....
And on this car with the chrome bumpers, I personally prefer the silver exhaust....better still if it was stainless.
WCB Hitler's Hot Rod
« Reply #16 on: May 22, 2014, 21:38:57 pm »
If you must go with that exhaust on your car; I would choose black or wrinkle red paint....
glenn
« Reply #17 on: May 23, 2014, 02:58:43 am »
Because you won't be able to install a stock engine and exhaust after you blow up one engine and waiting for the next to be done.
Since I had the stock 1600DP sitting, it might as well get installed so I can drive it around.
Must of been the only Berg 5 mated to a stock engine.
Glenn
www.DasVolks.com
« Reply #18 on: May 23, 2014, 06:10:24 am »
Vintage speed stainless exhaust on my 1303S, 1915ccm, IDF`s and a beatiful 010 from Glenn;
-BB-
drgouk
« Reply #19 on: May 23, 2014, 10:00:31 am »
-BB-
Beetle Bug, What are the vintage speed exhausts like for making power? I was interested in there 13/4 system
David
« Reply #20 on: May 23, 2014, 11:31:33 am »
David
Hi David, my 1915 engine produced 112hp on a very strict dyno with the Vintage Speed Superflo muffler, original size pulleys, belt and original, German heat boxes. It is a mild engine with CB round port heads and a Engle W120 in combination with 1:1 ratio rockers. On my engine the heat boxes are the bottle neck and not the Vintage Speed exhaust. I`m really happy with the exhaust and the sound is spot on where I want it be. Silent enough to really enjoy a long cruise. Unless you have a fire breathing monster I doubt that their 1 3/4" exhaust will restrict your engine more than the more commonly used systems from any other vendor.
-BB-
K-Roc
« Reply #21 on: May 23, 2014, 15:56:33 pm »
[/quote]
David
[/quote]
For the heck of it I fitted a 1-3/4 (44mm ) Vintage Speed exhaust to a 2332 that is currently in my 66,  it replaced an A1  1-3/4...
On the street I cant feel any difference in power, so IF there is a loss in peak power over the A1 its not much... ( this motor went  12.60's N/A at 1900 lbs...)  my plan was to do a back to back chassis dyno test but never got around to it. The fit of the exhaust is /was awesome.
I have changed the gearing in the trans to a more highway friendly ratio, and am thinking of pulling the cage out as I dont drag race it any more, The best thing about the Vintage Speed to me is the exhaust note at highway speeds and the lack of the annoying exhaust resonation at 3400 RPM's cruising speed.  (4.12 with a .82 )
If you happen to have a stereo in your car you will be able to hear it  Wink
Sorry to take it off topic,  Glen I like the Black muffs with chrome tips!
drgouk
« Reply #22 on: May 24, 2014, 04:16:11 am »
David
[/quote]
[/quote]
Hi Darren, is this the muffler that your using? http://www.thesamba.com/vw/classifieds/detail.php?id=905840
Thanks David
K-Roc
« Reply #23 on: May 24, 2014, 04:38:08 am »
Just like that, except the pipes from the heads ( up to the flex pipe ) are a sandblasted Grey finish to help keeping head temps down.
The support brackets are different now ( beefier ) than in that picture.
Sam K
« Reply #24 on: May 24, 2014, 05:33:10 am »
IMO, black looks better, especially on an orange car. I've always loved the look of dual QP's. Reminds me of when I started modifying my bug in the early 90's Before fat boy style mufflers were around everybody had quiet packs or a stinger. I've been thinking about building a set for the large flange merged exhaust on my car for a while now. My be time to get on it.
« Reply #25 on: May 24, 2014, 07:16:58 am »
i must ask this question here as the vintage speed has the same setup.
is there a difference in performance between a two and two merged header like the vintage speed one described above and a more 'conventional' 4 into 1 merged header?
the reason i ask is that a 2+2 may be a good way to shorten exhaust headers, and porsche uses this type on there 911s and they are not on the shy side of horsepower engines.
K-Roc
« Reply #26 on: May 24, 2014, 16:28:51 pm »
Hi Nicolas, read my reply 4 posts up ^^^^
cheers
« Reply #27 on: May 24, 2014, 19:47:50 pm »
cheers
yep i saw it, i even read it, but i must have had a goldfish moment there… sorry 'bout that!
so no real, dramatic difference. so how much does the header length influences hp or torque? it must have some (maybe even a lot) influence, so why are there not more performance based 2+2 headers?
if memory serves me right, i think JPM made a short as possible header for a customer or the mouse motor that was made to the calculations of what would work best.
Taylor
« Reply #28 on: May 24, 2014, 21:19:11 pm »
I also like the look of dual quiets but my 1.75" header was an issue with its 2.25" collector so I came up with this compromise.   This is a true performance set up where form followed function but still got the look I was after. [ Attachment: You are not allowed to view attachments ]
« Last Edit: May 24, 2014, 21:21:04 pm by Taylor » Logged
Sam K
« Reply #29 on: May 25, 2014, 17:06:39 pm »
That's about what I would like to do. What mufflers and tubing diameter did you use?
