October 12, 2026, 13:14:18 pm
its been a long time, but tis getting there!
5
6
7
Topic: its been a long time, but tis getting there! (Read 135101 times)
Martin
Cash Converter....
Re: its been a long time, but tis getting there!
Reply #150 on:
August 17, 2009, 09:23:53 am »
A few updates....
New tanks, Fuel and ice tank.
Front air dam from the top
Front air dam from the front. this will be painted black and i'll fix the number plate to it.
its also had a rear end review to stop it going all saggy on the start line.
Martin
www.taylormachine.co.uk
OFF/500
jamiep_jamiep
Reply #151 on:
August 17, 2009, 10:46:36 am »
Looks good Martin, when will you be trying it out?
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Martin
Cash Converter....
Reply #152 on:
August 17, 2009, 11:31:38 am »
next outing is a the euro's in Comp Eliminator. Ive not got any time before that.
Martin
OFF/500
kev d
Reply #153 on:
August 17, 2009, 18:00:52 pm »
Is that all the mods finished for now then?
Cheers,
Kev
Martin
Cash Converter....
Reply #154 on:
August 17, 2009, 19:35:27 pm »
Quote from: kev d on August 17, 2009, 18:00:52 pm
Cheers,
Kev
I got a few more things to do, I'll post them when there complete
Martin
OFF/500
Lee
Reply #155 on:
August 17, 2009, 20:05:30 pm »
Quote from: Martin on August 17, 2009, 09:23:53 am
A few updates....
these look cool. Great fab work
Just out of interest. How is the drop/height for the front dam determined?
Martin
Cash Converter....
Reply #156 on:
August 17, 2009, 22:49:05 pm »
its got to be driven on the road, so it cant be too low.
We'll be able to see if its working from the suspension data logging.
Martin
OFF/500
Martin
Cash Converter....
Reply #157 on:
August 28, 2009, 09:18:32 am »
Looks like my new cam will be ready next week in time for the euros.
I keep looking at the can of sonoco 109 wondering how much more power is in there. And comp eliminator isnt a street car class........
LOL
Martin
OFF/500
Fasterbrit
Reply #158 on:
August 28, 2009, 21:03:32 pm »
Quote from: Martin on August 28, 2009, 09:18:32 am
LOL
Put it in, turn up the boost and hang the f@ck on
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
Martin
Cash Converter....
Reply #159 on:
September 22, 2009, 10:43:39 am »
Updates......... Updates........
well the front air dam works a treat, the car has stopped trying to fly, I'll just have to keep an eye on it as the mph starts to clime.
had a very good time at the euro finals, the best track i have ever driven on. Had a few issues with bogging at first due to the track, but i tuned the clutch round it and messed with the 2 step retard to get 28 psi boost on the start line. this resulted and a best time of the day of 9.86 @142 mph. the MPH was down in its usual.
After a look at the data logs No 3 EGT was running cooler than the rest so upon investigation No3 inlet rocker bearings had failed. This may be due to the springs starting to go off and starting to hammer the rocker as they start to bounce. I wont be able to see until i strip the motor down.
After looking into it a lot more it would seam the Rocker bearings are not up to the job, especially as I'm going to have to go up on spring rates with my new cam. So it looks like a redesign to make the rockers last the distance. I've looked at Jesel and many other rocker manufactures, bit can't fine a design that I'm happy with. So it looks like i may have to make my own.
I have also had some issues with the charging side of the car, the small race alternators that i have been using are a pile of Poo! and just not up to the job of charging a simple system never mind mine. I have found a really nice 75amp alternator and now the car is running at 14.4 volts all the time, it has really made a difference to the ignition system and the whole electrical system, brighter lights better starting and the motor sounded a lot crisper.
I had to move the fuel pump to get the new alternator in, so i made a whole new bracket to hold them both. really happy with this bit now.
that's it for now, until i strip the motor down to evaluate bearings, new rocker requirements etc.
Laters
Martin
Last Edit: September 22, 2009, 10:56:13 am by Martin
Martin
OFF/500
Fasterbrit
Reply #160 on:
September 22, 2009, 20:16:14 pm »
Congrats on your first 9! Well done
www.air-kraft.com
black_bullitt
Reply #161 on:
September 28, 2009, 18:49:16 pm »
Congrats on running the 9 Mr T, good luck with the rebuild.
kev d
Reply #162 on:
September 28, 2009, 19:07:27 pm »
Congratulations on the 9 matey
Out again this year?
Cheers,
Kev
Martin
Cash Converter....
Reply #163 on:
January 11, 2010, 09:42:04 am »
More updates........
Looks like weve got a solution to the rockers (thanks Don!)
Ive got a new cam to tryout as the last one wasnt just how i wanted it. Im changing onto billet cylinders this year as the cylinder preshure is going a lot higher.
My Fix to Broken swing axles.....
Did this CV convertion to my mendeola last year, tested it at the finals and it didnt bust! launched at 28 psi seams to have fixed the broken axle situation.
The details are on my website.
http://taylormachine.co.uk/Taylor_Machine_Services/930_Cv_Convertion.html
Im now working on a sequential shifter for the trans, hopfully going to make it clutchless shift so i dont have to let off the power. The shifter is first, then im working on making a gearset with dog engagment. So no more busted prorings!
must get back to it, this winter seams too long already!
Martin.
Martin
OFF/500
Fasterbrit
Reply #164 on:
January 11, 2010, 09:54:04 am »
Looking very cool Martin. Love the startline shot
www.air-kraft.com
jamiep_jamiep
Reply #165 on:
January 11, 2010, 17:20:04 pm »
That sounds a great setup Martin....
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Reply #166 on:
January 12, 2010, 10:37:47 am »
With this amount of power, I bet you would get a kick out of watching the Bonus track on the 2009 SCC dvd, where Skinne takes you on a guided tour on the IRS setup on his 9.01 florpan bug. There are some neat tricks under there.
Martin
Cash Converter....
Reply #167 on:
January 12, 2010, 16:49:48 pm »
where do i get one?
Martin
OFF/500
Reply #168 on:
January 13, 2010, 00:40:02 am »
www.sccevent.com
kev d
Reply #169 on:
January 13, 2010, 07:57:20 am »
Quote from: JHU on January 12, 2010, 10:37:47 am
Just ordered mine
Martin
Cash Converter....
Reply #170 on:
January 13, 2010, 11:05:58 am »
done!
Martin
OFF/500
Reply #171 on:
January 13, 2010, 12:42:09 pm »
I hope you get something out of it!
...and keep on innovating!
Martin
Cash Converter....
Reply #172 on:
January 19, 2010, 12:11:16 pm »
Got the DVD,
I can see what you mean, but its nothing im not doing already. But very very interesting.
Martin
Martin
OFF/500
Reply #173 on:
January 19, 2010, 14:11:55 pm »
Quote from: Martin on January 19, 2010, 12:11:16 pm
Got the DVD,
Martin
Glad you enjoyed it, myself I just dig when you get the backside of a fast car...like this thread. I think both you and him are sort of the creative type, that always evolve things instead of giving up!
And thanks for supporting the SCC!
Martin
Cash Converter....
Reply #174 on:
January 19, 2010, 21:14:12 pm »
Nah I can't give up! i may take a breather but never give up!
I'd love to come and race at the SCC this year.
Maritn
Martin
OFF/500
dcuplover
Reply #175 on:
April 03, 2010, 21:40:47 pm »
what engine management are you using?
Martin
Cash Converter....
Reply #176 on:
April 03, 2010, 22:27:53 pm »
AEM
can be found at
www.aempower.com
Martin
OFF/500
m.m.p
Reply #177 on:
April 12, 2010, 22:25:36 pm »
keeno's coming to get ya, keeno's coming to get ya
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
Martin
Cash Converter....
Reply #178 on:
April 13, 2010, 22:52:48 pm »
Quote from: m.m.p on April 12, 2010, 22:25:36 pm
LOL Bring it on Keeno!
Julie is keeping that bet nice and safe
Martin
OFF/500
Martin
Cash Converter....
Reply #179 on:
May 25, 2010, 19:41:15 pm »
blimy its been a while since i updated this.... Baby's have been getting in the way!
Right then, Crower rockers are now across the atlantic on the Red Baron, to help them out of a hole. all the bearing carriers were cracking and just not up to the job, Team Red Baron are using a different style of bearing thats helping them last a little longer. but this is a short term fix.
So what ive done with the help of Don is use a set of there development rockers, but ive had to mount them in a similar way to the crowers, as i didnt want to weld on the billet heads to much.
take a look..
this is how it started off
Just to get the layout right.
I have also changed to sump scavenge so i have one -12 line from it to the pump, Hope it works otherwise i'll be ordering another sump! lol
the red bit on the end is an inline cleanable -12 filter
theres also a new cam grind in there, trying some stuff out again....
if all goes to plan i should be on the dyno this week to see if all this rubbish works out
Laters
Martin
Martin
OFF/500
5
6
7
