October 12, 2026, 13:15:44 pm
its been a long time, but tis getting there!
5
7
Topic: its been a long time, but tis getting there! (Read 135105 times)
Martin
Cash Converter....
Re: its been a long time, but tis getting there!
Reply #60 on:
November 23, 2007, 11:53:02 am »
now this looks like its going work!
going to start machining the heads today, I'll post some pictures of the proces
wooo wooo back on the rollers very soon!
Martin
www.taylormachine.co.uk
OFF/500
Sander/DVK
Reply #61 on:
November 23, 2007, 15:08:28 pm »
Nice rockers!
Pauter Machine?
Martin
Cash Converter....
Reply #62 on:
November 23, 2007, 15:23:44 pm »
Quote from: Sander/DVK on November 23, 2007, 15:08:28 pm
Nice rockers!
Pauter Machine?
Crower, intended for a v8
Last Edit: November 23, 2007, 16:54:50 pm by volksman
Martin
OFF/500
Martin
Cash Converter....
Reply #63 on:
November 28, 2007, 21:42:02 pm »
Getting stuck into machining the heads....
This one of the heads all set ready to machine.
Mid Machining
After Machining...
To get the geometry correct, i set a valve at half lift with my spring hight tool
I used slips to get the rocker hight set, then I machined the same amount off the bottom of the ali spacer.
Last Edit: November 28, 2007, 21:48:25 pm by volksman
Martin
OFF/500
Fasterbrit
Reply #64 on:
November 28, 2007, 23:21:31 pm »
Some suberb work going on here trailer
Keep them pix flowing
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
Reply #65 on:
November 29, 2007, 09:08:39 am »
that is really impressive, but i have no idea what part this is in a vw engine
Reply #66 on:
November 29, 2007, 14:56:55 pm »
Quote from: nicolas on November 29, 2007, 09:08:39 am
A Real High Dollar Cly Head and Rocker Assy. $$$$$$$$$$$$$
Martin
Cash Converter....
Reply #67 on:
November 29, 2007, 23:59:22 pm »
Quote from: Shubee2 (DSK) on November 29, 2007, 14:56:55 pm
Never thought of it like that... well you go down a path and you just can't turn back can you! all for the quest of HP!
Martin
OFF/500
Reply #68 on:
November 30, 2007, 10:06:16 am »
Quote from: volksman on November 29, 2007, 23:59:22 pm
i had no idea there was a path so far of conventional vw parts... but i am very impressed. keep on posting pics.
Reply #69 on:
November 30, 2007, 15:41:58 pm »
How are the new Rocker stands going to be atached to the Head?
Martin
Cash Converter....
Reply #70 on:
November 30, 2007, 16:08:04 pm »
They are bolted, by 6off 7/16 unf socket caps, the material they are going into is well over 12mm thick
Martin
OFF/500
Reply #71 on:
November 30, 2007, 18:56:07 pm »
Quote from: volksman on November 30, 2007, 16:08:04 pm
Oh, so you're not going to rely on Superglue after all? What changed your mind?
Reply #72 on:
November 30, 2007, 19:34:10 pm »
Why did the Original Stands have to be milled off it seems it would have been stronger the old way? I would think after A matter of time the Threads will go away for the retaining Bolts there is a lot of force with all the RPM and Valve Spring Pressure?
Martin
Cash Converter....
Reply #73 on:
December 01, 2007, 09:44:05 am »
Quote from: Shubee2 (DSK) on November 30, 2007, 19:34:10 pm
I know what your saying, and yes i did look to see if i could use the stands but they were just in the wrong place. I supose if Paradise are going to make any more, then they would incorporate this set up into the head.
As for it failing, we will have to see, i do have a backup plan if this happens. But it envoles a lot of welding and i realy dont want to have to do that.
Martin
OFF/500
Reply #74 on:
December 01, 2007, 19:07:58 pm »
Looks Good Martin Just Hope it Holds if it Broke A Rocker and with Strong Springs an High Lift theres a Ton of Pressure on those Bolts and Threads
Last Edit: December 02, 2007, 03:12:38 am by Shubee2 (DSK)
Martin
Cash Converter....
Reply #75 on:
February 01, 2008, 18:50:09 pm »
ok, Motor all finished ready to go back in.
New rocker setup,
Martin
OFF/500
71CALRIPPER
Reply #76 on:
February 01, 2008, 19:02:06 pm »
Just a little bit SCARY
roland
lates are the new splits...
Reply #77 on:
February 01, 2008, 19:03:14 pm »
How wild is that!
Half of the stuff on that engine i don't even know what it is...
Brillaint!
Martin
Cash Converter....
Reply #78 on:
March 08, 2008, 18:26:41 pm »
Not posted for a while,
Got the motor and box all back in, i decided to detail the back half of the chassis seeing as it was mostly all over the floor!
After getting the leads the right way round the motor fired right up, and settled down to a nice idle...
Off to crack a beer, going to put the car out side and leave it running for an hour or so, just to make sure the new rockers are all happy, then off to the rollers next week (hopfully!)
First proper race is at Easter, still more jobs to do, but i feel much closer now.
catch you laters .....................(Martin cracks open a beer)
Martin
OFF/500
Martin
Cash Converter....
Reply #79 on:
July 18, 2008, 23:00:58 pm »
Sorry its been so long for an update, but after changing the following:
cam
valves
Valve springs
water pump
Radiator
and a shit load of work and pain!
we finaly got the car to make power on the dyno!!!!!
regular pump gas, no water injecton running at the moment, fat as you like on the top end 17 deg advance = 500+ hp, this was acheved time after time, the motor staid cool and nothing fell off.
want to make some changes but i'll keep you posted
Martin
OFF/500
Martin Greaves
10.88@128.58
Reply #80 on:
July 18, 2008, 23:14:06 pm »
nothing fell off
Yet
Prowagen
Reply #81 on:
July 18, 2008, 23:26:17 pm »
Martin are those new rockers off a V8 or something they look beefed!
Rob.
benssp
www.callookvw.com
Reply #82 on:
July 20, 2008, 11:57:06 am »
he ran a 10.396 @ 139.40mph at bug jam in the street eliminator class, not bad for pump gas and treads
Russ Fellows has gone 9.51@141mph too
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
Martin
Cash Converter....
Reply #83 on:
July 20, 2008, 23:40:47 pm »
Quote from: benssp on July 20, 2008, 11:57:06 am
Sorry would have gone faster, but it was only my 4th run in the car.
Martin
OFF/500
benssp
www.callookvw.com
Reply #84 on:
July 21, 2008, 09:02:30 am »
Don't apologise, that's an awesome time for the first meet, 139mph!
can't wait to see it run, can i call shotgun on an observed cruise?
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
jamiep_jamiep
Reply #85 on:
July 21, 2008, 09:40:37 am »
Saw your run Martin, will post a pic up in a bit. Car looked sounded and went awesome!
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
benssp
www.callookvw.com
Reply #86 on:
July 21, 2008, 10:56:10 am »
couple of pics from t'internet
looks tough
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
Prowagen
Reply #87 on:
July 21, 2008, 12:32:18 pm »
Well done great acheivement in such little track time! Will you have it up at shakey in august?
Rob.
Martin
Cash Converter....
Reply #88 on:
July 21, 2008, 14:04:42 pm »
Quote from: Prowagen on July 21, 2008, 12:32:18 pm
Rob.
Just try and stop me!
Martin
OFF/500
Frank LUX
Back...Soon...hopefully!!!
Reply #89 on:
July 21, 2008, 15:10:03 pm »
Hey Martin, coming over for DasDragDay#6...
Frank
5
7
