October 14, 2026, 01:05:45 am
| | |-+  Rear engine brace needed with solid mounts ?
Author Topic: Rear engine brace needed with solid mounts ?  (Read 8112 times)
Rocket Ron
It's old school for a reason
« on: June 02, 2014, 21:58:23 pm »
Hi
Is there any need to run a rear engine brace with solid gearbox mounts front and mid
Frame horns are tied into the cage
What's your thoughts ?
Ps don't have much to hang it off anyway as it's cut way quite a bit in the rear
« Last Edit: June 02, 2014, 22:05:43 pm by RON ELLIOT » Logged
13.12 @ 101.84
Grooving out on life
« Reply #1 on: June 02, 2014, 22:18:02 pm »
Jim Smith recommended I still use mine after I had my cage fitted.
But if you have no inner wings not sure what you can do anyway
Lee
Rocket Ron
« Reply #2 on: June 02, 2014, 22:24:40 pm »
I'm thinking the light weight of the car makes a difference lee
Must be 80-100 kg lighter than your car wouldn't you say ?
13.12 @ 101.84
« Reply #3 on: June 02, 2014, 22:42:48 pm »
You could be right with the weight.
Just give it a go....
Lee
Rocket Ron
« Reply #4 on: June 02, 2014, 22:45:28 pm »
Just didn't want to end up with a two piece gearbox
13.12 @ 101.84
« Reply #5 on: June 02, 2014, 22:51:20 pm »
What box you putting in?
Rocket Ron
« Reply #6 on: June 02, 2014, 22:54:45 pm »
The close ratio built by Pete
13.12 @ 101.84
« Reply #7 on: June 02, 2014, 23:07:30 pm »
Out the white car?
Lee
Rocket Ron
« Reply #8 on: June 02, 2014, 23:08:01 pm »
Yep
13.12 @ 101.84
« Reply #9 on: June 03, 2014, 07:12:25 am »
It will be fine, old cab doesn't use a traction bar since the cage was tied into the frame forks
Rocket Ron
« Reply #10 on: June 03, 2014, 07:52:47 am »
13.12 @ 101.84
NoBars
« Reply #11 on: June 06, 2014, 14:45:32 pm »
i have the motor mount tied to the package tray where the roll bar plates are welded in, no brace. works good.
