September 23, 2026, 20:18:02 pm
| |-+  For sale!
| | |-+  Mild engine parts,94mm pistons & fuel tank
Author Topic: Mild engine parts,94mm pistons & fuel tank  (Read 2344 times)
Dead Dog
« on: June 05, 2014, 11:53:42 am »
  • Std fit Beetle fuel tank (off 1971 1200) with 1/2" / 13mm barb fitting and original outlet(used as fuel return) £40
  • Genuine VW 69mm crank, forged-welded-counter weighted-8 dowel. std case .50 on the crank (bare crank, no gears,spacers,bearings) £ 150
  • Engle 110 cam (no gear) and followers (slight pitting on the followers), Low Bugget 1.25 rockers and 4340 chromo shafts (slight wear on shaft)  SOLD
  • Mahle 94mm pistons, non stroker - I've three £30 ea or £80 for all
Prices excl postage, I can also get them to Cal Look Drag Day
Due to an upgrade I have parts available, as they are mild parts, they are more than likely going in a mild daily engine, the parts that do show sign of wear will be fine to use in such an engine( and priced accordingly ), as opposed to my drag engine Wink
« Last Edit: June 10, 2014, 13:12:23 pm by Dead Dog » Logged
VWDRC PRO 102 - 11.85 @ 107mph
T1 1914 omex 600 t3/4 turbo
WRP Paint & Restoration - VWDRC Sponsor 2012 & 2013
Dead Dog
« Reply #1 on: June 10, 2014, 13:12:47 pm »
Cam, followers & rockers sold
