October 13, 2026, 07:37:32 am
| | |-+  IDA accelerator cam/roller
Author Topic: IDA accelerator cam/roller  (Read 8154 times)
63 ripper
« on: June 09, 2014, 10:52:15 am »
Hi. Which products are people using to keep these lubricated/greased. Everything I have tried doesn't seem to stay on, leading to grooves wearing in the roller. You end up with a horrible throttle response and a lean condition.
Has anyone tried some sort of sealed bearing instead of the roller ?
These are Spanish IDAs, it's possible the old ones wear less.
Thanks in advance..
JG54
« Reply #1 on: June 09, 2014, 16:53:40 pm »
I use a small bronze sleeve pressed over orig roller. I use Bosch distributor grease or anti sieze. Make sure your ramp is burr free and smooth. I have to re-lube mine maybe once every 6 months driving the car 3-4 x a week.
63 ripper
« Reply #2 on: June 09, 2014, 18:08:43 pm »
Interesting, thanks Jim.
I guess that the strength of the material is not so important then, brass being softer than steel ?
I'm surprised no one (Jaycee etc) has started producing an upgraded product...
JG54
« Reply #3 on: June 09, 2014, 18:31:04 pm »
I heard somewhere that Gene Berg Ent had an upgrade.
Had I been more maintenance minded in my younger years with my IDA's, my original rollers would look better today. I used to get a real notchy pedal and go hog wild disassembling linkage and lubricating all pivot points and heim ends, and cable. Usually didn't help much. A friend of mine in DKP with years more experience pointed out my rollers were prob flat spotted and rough. He suggested Bosch grease. My rollers were flatted, hence the sleeves (going on 7 years now, no flats).
A lot of 48's I've worked on for buddies have had dry/rough rollers with a flat spot ground into them. Sometimes they even squeak.  Shocked
« Reply #4 on: June 09, 2014, 18:45:50 pm »
It has been done.
63 ripper
« Reply #5 on: June 09, 2014, 19:50:58 pm »
I bought these about 3 years ago from Bergs when I needed the adjustable pump ramp. They look like steel rollers, the finish on the ramp is different though, like they have been treated. These rollers are now flatted...
Perhaps they have an upgrade now (not listed on website)
JG54
63 ripper
« Reply #6 on: June 09, 2014, 19:51:47 pm »
It has been done.
Did it work ?  Smiley
JG54
63 ripper
« Reply #7 on: June 09, 2014, 19:54:43 pm »
double post
JG54
