November 02, 2026, 19:30:15 pm
Engine diapers/trays Oil downs and solutions
Topic: Engine diapers/trays Oil downs and solutions (Read 42376 times)
Re: Engine diapers/trays Oil downs and solutions
Reply #30 on:
June 13, 2014, 12:24:33 pm »
Quote from: richie on June 13, 2014, 08:24:44 am
Here's a link to FTD for anyone interested
http://www.fasttimedesign.com/
They are nice if you have a race engine and do not want to spend time making a tray.
Best rgs
Kalle
Reply #31 on:
June 13, 2014, 13:45:49 pm »
Do they heat soak the bottoms of cylinders/heads even more?
A race engine without cooling would need all the air they can get I would assume?
spanners
Reply #32 on:
June 14, 2014, 21:24:33 pm »
Anything with the 'balistick' tag will cost ya! , Bonding is so overlooked and underestimated, I do most stuff I used to spend hours drilling, bolting, welding, For those that can't weld it's a huge plus, oil cooler ducting, foot plates, all maner of brackets, i started repairing broken stuff 'in the field' with it, then found it stood up better than the original, fibre glass wing repar patches etc are on for good, I would bond that above type of catch tray at the corner folds, even the mountings, you won't shift or break them, do a test piece if you need convincing, tiger seal is a good one, you just need positive holding tools while stuff cures, I have dozens of wee spring clamps from the 99p shops, even clothes pegs work for small stuff, the only downer is getting parts in the right position straight off, you won't move stuff after it's cured, also it's really only a one shot tube I find, I've found no way to stop a part used tube cooking, tho I'm looking out for an old lab vac vessel to store them in, that's probably the answer!
As for affecting handling, they won't be helping that's for sure, there must be a drag increase with the induced underside vortexes, at the terminal speeds you guys reach, some effort to air flow the trays would see some gains, metal or plastic leading/trailing edge fairing needed! Imagine it in yer hands at 50 mph, bad eh? Now emagine hanging on to it at 150 ? Just a thought, but Can't hurt..
Best regards, spanners.
Turbo_Rich
Reply #33 on:
June 14, 2014, 23:43:08 pm »
Good thought on the aero, maybe if the front of the tray was more akin to a well sump guard it may help?
My own setup limits me to having a couple of trays under the heads that covers the rocker covers/push rod tube area. Try as I might to eliminate a weep from the push rod tubes there always seems to be at least one when is cold but goes when hot! Anyway, my thoughts are I'd rather not risk having one drop cost me a chance of a run or costing someone else theirs!
Reply #34 on:
June 15, 2014, 07:23:56 am »
I guess you could bond it together, having used tigerseal to hold interior panels on I know they can be pulled off so it could come apart with enough air pressure or maybe even the weight of lots of oil and that would be the worse time, something like the 3m bonding stuff would be good enough
It needs a decent lip all round to keep any oil in, if you have a bad leak and the sides aren't high enough it will still leak everywhere but anything is better than nothing to catch the drips, but they don't usually close the track for hours
Rich if you put a pic up of your set up maybe we can help with an idea of how to cover the whole engine
jamiep_jamiep
Reply #35 on:
June 16, 2014, 11:05:45 am »
Great info, thanks for sharing Richie.
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Reply #36 on:
June 16, 2014, 12:55:11 pm »
Quote from: kaferboy on June 16, 2014, 11:05:45 am
No problem Jamie,
as we haven't found a way to sort the weather out yet we need to make the most of what track time we do get
dannyboy
Reply #37 on:
June 16, 2014, 13:14:33 pm »
there could be a nice little earner in these i reckon you should make a couple up and sell them ,see how they go. the absorbant pads are the hardest thing to get in uk from what i can see someone at the track told me they use litter pads from a pet shop ? not sure how fireproof they are though
8.77@156.8mph
O/FF 60
Reply #38 on:
June 16, 2014, 19:00:43 pm »
Quote from: dannyboy on June 16, 2014, 13:14:33 pm
I have a stock of the correct material so that wouldn't be a problem, I just need the tracks to start charging those that oil it down
and then sell them easily
dannyboy
Reply #39 on:
June 16, 2014, 20:04:13 pm »
pm me a price for enough pads to make up a tray if you got spare as my trays are not going back on this season im going to rip off your design
8.77@156.8mph
O/FF 60
Reply #40 on:
August 18, 2014, 11:48:16 am »
Good to see pics appearing of containment devices being made and fitted, I have seen a few different designs made now and they all look good
Reply #41 on:
August 18, 2014, 12:05:31 pm »
Quote from: richie on June 10, 2014, 11:29:53 am
It doesn't need to be complicated, this goes from valve cover to valve cover, and from pulley to flywheel, has a 2inch lip all round as is required in some USA race classes, and is lined with fire resistant absorbant material to catch any mishaps!!!!
But your's does not work with wheeliebars :-(
www.Udobeckertuning.de
Reply #42 on:
August 18, 2014, 13:29:42 pm »
I made one for Bernie that he designed to work round wheelie bars and the chute mount so it can be done
, maybe he can put a picture up here to show it?
Rocket Ron
It's old school for a reason
Reply #43 on:
August 18, 2014, 16:10:19 pm »
Quote from: richie on August 18, 2014, 13:29:42 pm
There's a few on Facebook of Bernies tray, I'll see if I can repost them here
13.12 @ 101.84
Grooving out on life
Rocket Ron
Reply #44 on:
August 18, 2014, 16:20:14 pm »
13.12 @ 101.84
Berger
www.bugrent.no
Reply #45 on:
August 18, 2014, 17:06:18 pm »
Here is one I made for my Ghia, goes all the way to the nose cone on the gear box
This is my simple religion:
-Be cool
-Don't be an asshole
dannyboy
Reply #46 on:
August 18, 2014, 19:28:26 pm »
Quote from: Berger on August 18, 2014, 17:06:18 pm
this is pretty much the same as the tray i made yesterday
8.77@156.8mph
O/FF 60
Bernard Newbury
9.50 @ 141 MPH
Reply #47 on:
August 18, 2014, 21:59:22 pm »
Quote from: Ron Elliot on August 18, 2014, 16:10:19 pm
Thanks Ron. It proberly would not pass the American spec. but as Ritchie said anything is better then nothing.
Rocket Ron
Reply #48 on:
August 18, 2014, 22:05:28 pm »
No problem
13.12 @ 101.84
dannyboy
Reply #49 on:
August 18, 2014, 22:29:18 pm »
its funny how bernies looks shit hot and mine looks like its been built by a carpenter with a bit of 4x2 and a claw hammer
8.77@156.8mph
O/FF 60
Berger
www.bugrent.no
Reply #50 on:
August 19, 2014, 06:53:39 am »
Another interesting thing I have noticed is, even if you don`t have a major oil leak and engine/gear box looks clean, after running with the tray for a while there are quite a few drops of oil in that tray anyway! And then you multiply this by the number of race cars going down the track....
As Kalle wrote, tray/diaper should be mandatory on all race cars, and even if its not, as a racer you should take responsibility and put one on
-Be cool
Happychappy
Reply #51 on:
August 19, 2014, 20:34:24 pm »
Here is mine .....
Just need to get the tray lining to finish it off.
Reply #52 on:
August 19, 2014, 20:54:16 pm »
Quote from: Happychappy on August 19, 2014, 20:34:24 pm
Here is mine .....
Looks good Paul, I got some liner for you, hopefully will leave it with Jim or Trevor in the next couple of weeks
Happychappy
Reply #53 on:
August 19, 2014, 21:38:49 pm »
That would be great cheers Richie
