August 12, 2026, 18:03:21 pm
| | |-+  KONI Shocks
Author Topic: KONI Shocks  (Read 10377 times)
Paul Bahnstormerz
« on: June 21, 2014, 07:51:55 am »
Hi,
Does anyone know the part number on Koni shocks for a ball joint beetle lowered with a adjustable beam, and what the original car they came from is?
Paul
Tourist
« Reply #1 on: June 21, 2014, 09:26:35 am »
Good morning Paul,
I've got it in my head they're from an Opel Kadett, but can't be certain.... Embarrassed
(I assume it's new ones you're after?)
Sorry if that's not much help Grin,
Martin Smiley
« Reply #2 on: June 21, 2014, 09:31:17 am »
Good morning Paul,
Martin Smiley
Yes that's correct Martin, and you need to drill out the top eyelet as its to small to bolt straight on
Paul Bahnstormerz
« Reply #3 on: June 21, 2014, 20:25:55 pm »
Drill top eyelet? Isn't the front shock a threaded rod that goes through the shock tower on a balljoint beam with some rubber bushes? Sure these aren't for early beetles?  Huh
« Reply #4 on: June 22, 2014, 00:31:08 am »
http://konimarket.com/collections/volkswagen
Jos
« Reply #5 on: June 22, 2014, 05:50:57 am »
I could be wrong but I believe you want front shocks from a '69-72 Opel GT. If that is correct, the part number you want is...
KONI-80-1580Sport
« Reply #6 on: June 22, 2014, 07:43:25 am »
No.
80-2275.
max, Der Bahnstormerz
« Reply #7 on: June 22, 2014, 16:57:53 pm »
Volkswagen
Beetle
1200 / 1300
with single joint rear axle    71-77   Classic
Front   80-1787
Rear   80-1350
Sport   Rear   80-1350Sport
Steering damper (not adjustable) / * For availability contact info@reinekeshop.de   Classic   Front   76-1293
Generally the std Koni's are fine for lowered cars, 'cause they have plenty of travel built in.
« Reply #8 on: June 22, 2014, 20:26:31 pm »
Brain fart, bottom eyelet Shocked  buy some then you will figure it out anyway Grin
Ron Greiner
DKP II
« Reply #9 on: June 23, 2014, 02:04:11 am »
The Koni number is 80-1580 from the Opel Kadett, you do have to drill out the bottom steel bushing to fit the Vw stud,
great shock to use since you can adjust the dampening. I had them on my 68 DKP bug back in 1976
« Last Edit: June 23, 2014, 02:05:48 am by Ron Greiner » Logged
« Reply #10 on: June 23, 2014, 12:37:21 pm »
Are they cheaper via the Opel route versus buying them from the shop for vw? These the red ones yes?
« Reply #11 on: June 23, 2014, 12:44:49 pm »
Its not the price,
VW length are to long for a lowered beam, they bottom out, the Opel version are shorter
« Reply #12 on: June 24, 2014, 00:00:41 am »
Ahhhhh got it! Thanks mate
Paul Bahnstormerz
« Reply #13 on: June 24, 2014, 08:56:22 am »
More modifying parts to work. The car is reminding why I gave up, years ago, it will be worth it   Angry
Doktor
« Reply #14 on: June 24, 2014, 11:14:50 am »
I have finished total restoration of my bug recently, and have fitted Koni shocks all round.
Front shocks are as per Torben's suggestion (sourced thru CSP, see item: 413 032 2275), ride quality is really good and front is lowered for about 4-5 centimeters.
dr.aircooled
RichardinNZ
« Reply #15 on: June 27, 2014, 00:46:17 am »
At what point are shorter front shocks needed?  I'd like to add some Koni shocks to my '58 (link pin) which is lowered about 1 1/2 to 2 inches at the front.  Will I be OK with standard length shocks?
At the moment if I'm travelling at a constant 20mph'ish (on the motorway!!) the front end gets into a rhythm of 'bounces'...I wonder whether this is the existing standard shocks?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
« Reply #16 on: June 29, 2014, 22:53:37 pm »
What do the Koni's ride like on a lowered ball joint bug? I currently have KYB mini shocks on my beetle (narrowed beam/dropped spindles) and its very smooth ride but wondering if its worth the expense to upgrade?
