October 14, 2026, 23:06:14 pm
KONI Shocks
Topic: KONI Shocks (Read 10704 times)
Paul Bahnstormerz
KONI Shocks
June 21, 2014, 07:51:55 am »
Hi,
Does anyone know the part number on Koni shocks for a ball joint beetle lowered with a adjustable beam, and what the original car they came from is?
Paul
Tourist
Re: KONI Shocks
June 21, 2014, 09:26:35 am »
Good morning Paul,
I've got it in my head they're from an Opel Kadett, but can't be certain....
(I assume it's new ones you're after?)
Sorry if that's not much help
Martin
Re: KONI Shocks
June 21, 2014, 09:31:17 am »
Quote from: Tourist on June 21, 2014, 09:26:35 am
Good morning Paul,
Martin
Yes that's correct Martin, and you need to drill out the top eyelet as its to small to bolt straight on
Paul Bahnstormerz
Re: KONI Shocks
June 21, 2014, 20:25:55 pm »
Drill top eyelet? Isn't the front shock a threaded rod that goes through the shock tower on a balljoint beam with some rubber bushes? Sure these aren't for early beetles?
Re: KONI Shocks
June 22, 2014, 00:31:08 am »
http://konimarket.com/collections/volkswagen
Jos
Re: KONI Shocks
June 22, 2014, 05:50:57 am »
I could be wrong but I believe you want front shocks from a '69-72 Opel GT. If that is correct, the part number you want is...
KONI-80-1580Sport
Re: KONI Shocks
June 22, 2014, 07:43:25 am »
No.
80-2275.
max, Der Bahnstormerz
Re: KONI Shocks
June 22, 2014, 16:57:53 pm »
Volkswagen
Beetle
1200 / 1300
with single joint rear axle 71-77 Classic
Front 80-1787
Rear 80-1350
Sport Rear 80-1350Sport
Steering damper (not adjustable) / * For availability contact
info@reinekeshop.de
Classic Front 76-1293
Generally the std Koni's are fine for lowered cars, 'cause they have plenty of travel built in.
Re: KONI Shocks
June 22, 2014, 20:26:31 pm »
Quote from: Paul Bahnstormerz on June 21, 2014, 20:25:55 pm
Brain fart, bottom eyelet
buy some then you will figure it out anyway
Ron Greiner
DKP II
Re: KONI Shocks
June 23, 2014, 02:04:11 am »
The Koni number is 80-1580 from the Opel Kadett, you do have to drill out the bottom steel bushing to fit the Vw stud,
great shock to use since you can adjust the dampening. I had them on my 68 DKP bug back in 1976
Last Edit: June 23, 2014, 02:05:48 am by Ron Greiner
Re: KONI Shocks
June 23, 2014, 12:37:21 pm »
Are they cheaper via the Opel route versus buying them from the shop for vw? These the red ones yes?
Re: KONI Shocks
June 23, 2014, 12:44:49 pm »
Quote from: andy198712 on June 23, 2014, 12:37:21 pm
Its not the price,
VW length are to long for a lowered beam, they bottom out, the Opel version are shorter
Re: KONI Shocks
June 24, 2014, 00:00:41 am »
Ahhhhh got it! Thanks mate
Paul Bahnstormerz
Re: KONI Shocks
June 24, 2014, 08:56:22 am »
More modifying parts to work. The car is reminding why I gave up, years ago, it will be worth it
Doktor
Re: KONI Shocks
June 24, 2014, 11:14:50 am »
I have finished total restoration of my bug recently, and have fitted Koni shocks all round.
Front shocks are as per Torben's suggestion (sourced thru CSP, see item: 413 032 2275), ride quality is really good and front is lowered for about 4-5 centimeters.
dr.aircooled
RichardinNZ
Re: KONI Shocks
June 27, 2014, 00:46:17 am »
At what point are shorter front shocks needed? I'd like to add some Koni shocks to my '58 (link pin) which is lowered about 1 1/2 to 2 inches at the front. Will I be OK with standard length shocks?
At the moment if I'm travelling at a constant 20mph'ish (on the motorway!!) the front end gets into a rhythm of 'bounces'...I wonder whether this is the existing standard shocks?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Re: KONI Shocks
June 29, 2014, 22:53:37 pm »
What do the Koni's ride like on a lowered ball joint bug? I currently have KYB mini shocks on my beetle (narrowed beam/dropped spindles) and its very smooth ride but wondering if its worth the expense to upgrade?
